shifter noise - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 04-24-2002, 02:57 PM Thread Starter
Thumbs down shifter noise
took my aftermarket shifter out yesterday (pro 50h) i know they are notorious for shifter noise, but put the stock one back in, and it is worse than the pro 5.0 what gives???? i am selling my car, that's why i took it out.
Duke A is offline
post #2 of 7 Old 04-24-2002, 05:39 PM Thread Starter
Duke A is offline
post #3 of 7 Old 04-24-2002, 07:22 PM
Did you check to be sure you didn't misplace any of the rubber bushings? Did you keep the stock inner rubber boot? I thought you had to cut it to get the Pro5.0 on... I could be mistaken though.
TrueBlue01Vert is offline
post #4 of 7 Old 04-25-2002, 08:23 AM Thread Starter
yeaah, i had to cut the stock inner boot, i thought that was the problem, but i wanted to make sure. so my best bet, is to go buy another innner boot, any idea how much one costs?????
Duke A is offline
post #5 of 7 Old 04-25-2002, 04:13 PM Thread Starter
Duke A is offline
post #6 of 7 Old 04-25-2002, 04:30 PM
no idea. shouldn't be more than a few (20) bucks.
check with your dealer I guess, I couldn't find it on a quick search of parts.com
post #7 of 7 Old 04-25-2002, 05:31 PM
blue88mustang's Avatar
You could probably glue the inner boot back together. Or maybe even sew it back together with some thread. The closer to original that you get that shifter boot, the less noise it will make. You may want to try adding some more rubber insulation between the handle and the shifter base.
Good luck.
88 LX 5.0 Vert
blue88mustang is offline
Strange "tick" or "thwack" noise on my buddy's car OVERK|LL GT & SOHC 0 07-13-2007 01:44 PM
Noise is driving me crazy!!!!!!! Need help Genuine GT & SOHC 7 08-06-2005 11:23 PM
Weird noise coming from shifter area dylan03 94/95 Tech 5 10-15-2004 11:12 AM
Phantom Vortech bad-bearing noise (long)... Clemens9 Superchargers 1 03-06-2004 06:08 PM
