17x11 rims? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 04-23-2002, 06:34 PM
Blk96snake
Guest
Posts: n/a
Question 17x11 rims?
Will I be able to fit a 17x11 rim on the rear of my 03 cobra? If not, what things
will cause me problems? (rear sway bar, shocks, etc.)
Thanks,
Turner
post #2 of 4 Old 04-23-2002, 08:32 PM
Check with Rancho or Superlift. They should have what you need to get them to fit. LOL Sorry, I just couldn't resist. Actually, I'm curious to see if anyone has done it yet and how.
98PONYEXCESS is offline
post #3 of 4 Old 04-23-2002, 08:40 PM
if it is the same IRS as the 99/01, then i would guess no. check the bolt that sticks out at about 10 o'clock that supports the rear subframe. but this also depends on the offset of the wheels you are talking about. the problem is thru suspension travel. it will hit tire/wheel. 1/4 spacer probably would fix it.
-Drew
00GT a-s/c
Drew00GTsc is offline
post #4 of 4 Old 04-23-2002, 09:17 PM
Smile
03 is the same as the 99/01's As long as you have the right wheel offset you will be fine. I'm running 17 X11 forgelines on the back of my car. Been on for over a year with no problems.
Tim
LR 01 Cobra is offline
