Your Input is needed inside (Somewhat Long)-------> - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 04-23-2002, 06:09 PM Thread Starter
Ok, I want your opinions on my choice of mods for my upcoming 98 Cobra. So far the list is as follows:
Drivetrain:
Moser 31-Spline Axles
Auburn HD 31-Spline Differential
FRPP Aluminum Driveshaft
FRPP Driveshaft Safety Loop
Intake:
DeMolet Motorsports 100mm Densecharger
PRO-M 80mm MAF
Exhaust:
Bassani Catalitic X-Pipe
MAC 2-1/2" Flowpath Cat-Back
Ignition:
MSD DIS-4 Ignition
MSD Tach Adapters x2
MSD RPM Acitvated Window Switch
Steeda Timing Adjuster
Suspension:
Eibach Pro-Kit Lowering Springs
Ground Pounder Caster/Camber Plates
Kenny Brown Super Subframe Connectors
Kenny Brown Rear Adjustable Lower Control Arms
FRPP HD Rear Lower Control Arms
Nitrous:
NOS 5171 Kit
NOS Remote Bottle Valve
NOS 12V Bottle Heater
NOS Purge Valve Kit
NOS Bottle Pressure Gauge
Gauges:
AutoMeter 2-1/16" Dual Gauge Pod
AutoMeter 2-1/16" 0-100 psi Electrical Fuel Pressure Gauge
AutoMeter 2-1/16" NOS Pressure Gauge
Other:
AFM Switch Pannel w/Momentary N20 Switch
Interior:
Corbeau Carrera Black Cloth Seats x2
Corbeau Custom Fit Bracket Kits x2
Corbeau Black 4-point Strap-In 2" Harness Belts x2
Exterior:
Saleen S-281 Rear Wing
Tires:
Front: Nitto NT 555 245/45ZR-17
Rear: Nitto NT 555R Drag Radials 315/45R-17
2011 Mustang GT C/S Coupe - Black on Black
SVTVENOM is offline
post #2 of 6 Old 04-23-2002, 11:01 PM Thread Starter
SVTVENOM is offline
post #3 of 6 Old 04-23-2002, 11:56 PM
Boss96's Avatar
Looks good, how about a bigger fuel pump though?
Bob
96GT with lots of mods
Boss96 is offline
post #4 of 6 Old 04-24-2002, 12:07 AM Thread Starter
NOS includes a "pusher" pump with the 5171 kit so I don't think another pump is needed.
SVTVENOM is offline
post #5 of 6 Old 04-24-2002, 12:38 AM
what are your plans for the car? Drag racing? Ditch the Auburn, you'll prolly toast it within 6 months, with high RPM launches on slicks anyway. Are you going to do these in any particular order? why not long tube or Shorty JBA headers? And just outta curiousity, what kinda wheels are you gonna run? It seems you do have a great idea of what to do with your car though, hope you have fun with it!
:erhaps a clutch?? You might toast the stocker soon!::
Charles is offline
post #6 of 6 Old 04-25-2002, 12:44 AM Thread Starter
Well the car already has these mods on it:
- K&N Air Filter
- Steeda Underdrive Pulleys
- Steeda 3pc. Adjustable Clutch Quadrant Kit
- Steeda Tri-Ax Shfiter (Base Not Installed)
- 35th Anniversary Shift Knob
- Paper Flames Billet Shift Bezel
- McLeod Clutch
- FRPP HD Pressure Plate
- FRPP 4.30 Gears
- DMP SpeedCal
- BBK Off-Road H-Pipe
- DMP MIL Eliminators
- Welded in Flowmaster Mufflers
- 99 Cobra Wheels
- Kuhmo Ecstas Tires
- Steeda Floor Mats
I want a street brawler that will see light/moderate track duty.
SVTVENOM is offline
