275/40R-17's on all 4 wheels??? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 04-22-2002, 11:16 PM Thread Starter
Question 275/40R-17's on all 4 wheels???
I'm looking at getting a new set of tires for my '01 Cobra, possibly Nitto NT-555R's. Will mount them on 17X9 wheels front & rear.
Anyone have this set-up??? Or maybe something similar???
(I see that the '03 Cobra uses this set-up, so maybe there are no problems???)
I'm concerned about clearance/rubbing issues....
Angus01Cobra is offline
post #2 of 9 Old 04-22-2002, 11:31 PM
do you have the stock wheels? if so, you have 17x8 and not 17x9. either way, you can fit a 275-40-17 on all four corners. With the 17x8, you'll have a slight budge but the tire will fit. I have 17x9.5 inch wheels all the around and have no problems with rubbing at all.
ASilver01GT is offline
post #3 of 9 Old 04-23-2002, 12:28 AM
I've got 275 40 sumitomo's on all four of my stock gt wheels. Fits well.
No Control is offline
post #4 of 9 Old 04-23-2002, 08:49 AM Thread Starter
Talking
BUMP
post #5 of 9 Old 04-23-2002, 08:54 PM
I have that set up on my car and have no problems. I think if you decide to lower your car you might run into a little rubbing in the front. Otherwise I say go for it.
CTCOBRAGUY is offline
post #6 of 9 Old 04-23-2002, 10:35 PM
Lowered 2 inches- 275's all around. No problem with rubbing.
post #7 of 9 Old 04-24-2002, 08:57 PM Thread Starter
I have the stock wheels currently, but I would be mounting the 275's on either 17x9's or 17x9.5's.
Those of you with the 275's, how does your car handle???
Same or better than stock???
post #8 of 9 Old 04-25-2002, 01:05 AM
Had 245 Sumitomo's before the 275's. After I installed the tires, I put the same pressure as the 245's. Car wandered all over the road. Bumped up to 40psi in all four, car handles like a dream.
post #9 of 9 Old 04-25-2002, 01:11 AM
Thumbs up
275 40 17's on Cobra R 17x9" rims and they handle awesome.
There's nothing like having more meat on all four corners and being able to push it harder through the turns. I gained at least 9mph on my favorite morning curve over the stock 17x8 with the 245's!
airtroop01 is offline
