To all coil over users. - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 04-20-2002, 10:42 PM Thread Starter
slosvt's Avatar
Question To all coil over users.
How high/low do you set your car at the track? I dont know if I should raise my car in the front for better weight transfer or lower it. Just hoping to get some different opions on what you guys have used and what works best for you. TIA.
slosvt is offline
post #2 of 6 Old 04-21-2002, 12:17 AM
Blown284's Avatar
Trader Feedback: (21)
Not being funny but I think stock height is perfect although it doesn't look very pretty
SOHC/DOHC Corral Moderator
Founder,
Part-Owner,
and
'00 Ford F-350 7.3 Turdbo Diesel
'03 Droptop Cobra
'99 Cobra "10 Second Street car" (SOLD!)
Blown GT ([email protected]) ---> SOLD
'00 Camaro (Couple of bolt-ons) - [email protected] (Jun 2011).
AOL: Blown284
Blown284 is offline
post #3 of 6 Old 04-21-2002, 10:08 AM Thread Starter
slosvt's Avatar
Does anyone know what the stock height is? The measured distance from the ground to the top of the wheel well would be really helpful.
slosvt is offline
post #4 of 6 Old 04-21-2002, 12:23 PM
Ares's Avatar
I run 1" lower in front then rear. I have front set at 27" at center of wheel lip, rear stock is 28"
Ed...
2004 Dodge Ram 5.7 Hemi, 8" lift 35's
1984 Mustang GT350 Vert - 351w side project
2004 Mustang GT Comp. Orange/5speed Best 1/4 [email protected], 1/8 [email protected], 1.57 60' - Best 60' 1.51, just a NA 2v
Ares is offline
post #5 of 6 Old 04-22-2002, 07:32 PM
jmeiers's Avatar
1.56 60ft. on my stock motor car with it sitting in the weeds in the front. About 25.5" from ground to center of fender lip.
Later, Jason
N/A 1997 Cobra (STOCK MOTOR without any BOOST... GRANNY-SHIFTED) - RETIRED
12.14 @ 114 MPH
1.61 60ft.
306 rwhp and 301 rwtq
Best 60ft. - 1.55
jmeiers is offline
post #6 of 6 Old 04-22-2002, 07:39 PM
Michael Clements's Avatar
Re: To all coil over users.
My advice would be to try different settings. First, get the car 4-corner balanced with your weight in the driver seat, as close as possible to the factory recommended ride heights. Then take it to an event and see how it drives.
After setting this baseline, you can adjust it on your own. Just turn the spring stops on the coilovers 1/2 turn up or down and write down how many turns you use so you can always return it.
You can do the same thing with alignment changes -- most easily, to toe in/out adjustments.
1999 Panoz Roadster; autox prepped with various bolt-ons and weight reduction
[We're moving out of state and the Panoz is currently FOR SALE]
Michael Clements is offline
