97 Cobra--- backfired????? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 04-19-2002, 11:49 PM Thread Starter
I hit the gas and about 6000 rpm I hear a bang.
Car hasn't acted funny since. I just installed BBK h-pipe.
Did fuel accumulate in the h-pipe???????
Any damage????
KeithCobraUH is offline
post #2 of 9 Old 04-20-2002, 12:46 AM
Blown284's Avatar
Trader Feedback: (21)
Backfiring as far as I know normally occurs when you're running very rich. Try resetting your computer and see if that helps out things so the computer will relearn things (that is, if you haven't done this already).
SOHC/DOHC Corral Moderator
Founder,
Part-Owner,
and
'00 Ford F-350 7.3 Turdbo Diesel
'03 Droptop Cobra
'99 Cobra "10 Second Street car" (SOLD!)
Blown GT ([email protected]) ---> SOLD
'00 Camaro (Couple of bolt-ons) - [email protected] (Jun 2011).
AOL: Blown284
Blown284 is offline
post #3 of 9 Old 04-20-2002, 11:59 AM Thread Starter
Thanks for the reply, I haven't reset it yet but have recently.
I figured it was caused by running rich.
Wierd for it to be so rich with not many mods----maybe MAC cold air is affecting MAF readings????
post #4 of 9 Old 04-20-2002, 01:09 PM
When I put my MAC cold air on my GT, I noticed that the pipe can slide in pretty far. I'm wondering if the pipe is too far in that there could be turbulence issues causing the MAF to mis-read.
98PONYEXCESS is offline
post #5 of 9 Old 04-20-2002, 02:52 PM
backfire
mine backfires around there two. 6-6.500. when i shift it backfires, whatching some footage from the track i have fire shooting out the tailpipe! i tried resetting the computer and nothing. new plugs and wires and still did it. i have a bbk' off road h also. i guess im just running really rich???
mikesslow50h is offline
post #6 of 9 Old 04-20-2002, 03:21 PM Thread Starter
I guess I need to get a chip so that it can lean it out.
post #7 of 9 Old 04-20-2002, 07:35 PM
Mine shoots fire also. Only on the 1-2 shift at ~6600rpm. It started when I got the off-road x-pipe. My mechanic said all the 4.6 cobras run very rich from the factory, especially at high rpm. With no cats to burn up all the extra fuel when you shift, the fuel can get ignited when air gets in their. The only thing that will cure this is to fix the rich mixture using a chip.
John Dimitropoulos
http://www.johndimo.com
Modular John is offline
post #8 of 9 Old 04-20-2002, 07:37 PM
COBRA90GT's Avatar
Lightbulb
The above explanation is your answer....it's just igniting downstream... (off-road pipe)
'01 Cobra Coupe From 6.01 - 9.15
'94 Cobra Coupe From 9.09 - 6.11
'14 F-150 Raptor SCAB Deliv 3.14
COBRA90GT is offline
post #9 of 9 Old 04-22-2002, 03:30 PM Thread Starter
My car didn't backfire the last time I got to 6000, but it hesitated.
Is this caused by it running rich?
New plugs help?
