svo blower/water injection guys get in here----> - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 11 Old 04-19-2002, 04:14 PM Thread Starter
well since i will be changing my defect head gaskets , i thought that i would port the crappy 97 head. do you think i will see any gains,the guy i know does a very good port job.
even more important i told my father that i would tap the water nozzle AFTER the blower in the upper intake.time to know wether this water injection is a bane or a blessing.
nowi need to know which spot to exactly tap.
any cutouts or any info is gladly helped .also if anyone has any idea try to show it by posting a pic.
thanks.
PURPLEMUSTANG is offline
post #2 of 11 Old 04-19-2002, 11:09 PM Thread Starter
post #3 of 11 Old 04-20-2002, 12:43 AM
PURPLEMUSTANG,
Here is a link to a water injection kit. Water injection
I'm sure they can help you out with placement.
willrace4food is offline
post #4 of 11 Old 04-20-2002, 12:55 AM
Guest
Purple.........you gonna upgrade to a 255lph pump?
Snyper5.8 is offline
post #5 of 11 Old 04-20-2002, 07:27 AM Thread Starter
well i did install my water injection ,i just have to know where to install it in (the upper intake of the blower).
post #6 of 11 Old 04-20-2002, 12:34 PM
With a busted head gasket you already have water injection! No need to install a kit.
GarrettW is offline
post #7 of 11 Old 04-20-2002, 01:23 PM
Water Injection = Roxxor!!
Milw96Cobra is offline
post #8 of 11 Old 04-20-2002, 02:24 PM
omar, you do know that you will need a check valve huh? here's what i am planning to do since it doesnt look like steve at SMC is going to finish the new module any time soon....
i am going to run 2 nozzles. probably #2's. one i will tap into the bend behind the blower before the compressor. the other i will tap on top near the small vacuum line as close to the front of the car and passenger side that i can get in the small space there. i will probably run a #1 before the blower and a #2 or 3 up top after. this is the best i could come up with.
11 KB GT at 15psi
11 CTSV
12 F350
11 Z71
stroked or blown? is offline
post #9 of 11 Old 04-20-2002, 08:40 PM Thread Starter
well have thought of that before that's why i already have a 15 psi check valve
I NEED PICS.someone post a pic of the svo blower with an arrow on where to tap it.
my gaskets will come in about 2 weeks ,so until then this thread will stay alive.
post #10 of 11 Old 04-21-2002, 12:19 AM
Put it right before or right after the bend of the intake right before the throttle body. Test pointing it with the intake stream and against.
I wouldn't put it before the supercharger.... some day you may want to switch and run a water/alcohol mix, or all alcohol, or you may get really brave and run a propane kit.....
http://www.dynamicracing.com/bb/view...t=propane+link
GrussR is offline
post #11 of 11 Old 04-21-2002, 08:32 AM Thread Starter
if i put it in the bend it will still be before the blower.
