360 rwhp 2003 cobra!?! - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 24 Old 04-19-2002, 11:00 AM Thread Starter
in the new 5.0 mag, they have a article in there stating pauls hi-perfomance dyno'd a 03 cobra and got 360 rwhp. and they something about taking the exhaust of, i guess put straight headers on, and got 400 rwhp. i remember people bit*en about maybe only getting 325-330rwhp. looks like they are stronger than what we think!
davescobra is offline
post #2 of 24 Old 04-19-2002, 11:07 AM
Corral Charter Member
Maybe. Maybe not. Keep in mind that car was a pre-production model. I do not think we can put any stock in dyno numbers until real cars are picked up by real owners and we start hearing reports from them on what they'll really do. I certainly hope that number is correct, but I want to see it from a real production model before I accept it as gospel.
E5.0
2006 Harley Davidson SE V-Rod
2009 Harley Davidson CVO Springer
2010 Corvette ZR1
snakecharmer is offline
post #3 of 24 Old 04-19-2002, 11:39 AM
Ford probably won't even let you look at your exhaust let alone change mufflers,catback etc. or they will have the "void warranty" stamp ready. They are probably sending out tampering notices to the dealers more so than they ever did on this model..
'98 RARE Bright Atlantic Blue/Black Cloth Cobra Coupe. Built 8/29/97 #009. Vortech 3.1SC
435/390 @6300w/10.6psi SCTDynotuned 4/24/07 by Lidio-Alternative Auto,
WILDPONY '98 is offline
post #4 of 24 Old 04-19-2002, 01:19 PM Thread Starter
even if it was pre-production, i would think it gives a little hope that they will run quick. all i want to know is when are they going to the 5.4 and supercharge that in a cobra????
post #5 of 24 Old 04-19-2002, 04:44 PM Thread Starter
anybody else have any opions?
post #6 of 24 Old 04-19-2002, 06:35 PM
My 2cents. I think Ford would be downright retarded if they knowingly brought a car in to be run on a dyno, and that those results would be published in a major Ford magazine, only to release cars that would lay down 320rwhp. And then if they do only put out 320rwhp people start changing the exhaust so they can get what the engine should have, only to have their warranty voided, which isn't legal. Ford should just tell us to jump in the lake now. That would also imply they gave MM&FF a "ringer" to test.
Let's hope that isn't true.
97DOHC is offline
post #7 of 24 Old 04-19-2002, 06:40 PM
red95svt's Avatar
I can't wait for the guys on "Horsepower TV" to get their hands on one. I can see it now:
Baseline run of 275 RWHP.
Add pulleys and Prolong and get 295 RWHP.
Add K&N, and get 315 RWHP.
Add exhaust and get 380 RWHP.
~Eric
red95svt is offline
post #8 of 24 Old 04-19-2002, 08:50 PM
treyGT's Avatar
ROFL, I can see it now, the Holley Thundermuff
black96GT
treyGT is offline
post #9 of 24 Old 04-22-2002, 01:25 PM Thread Starter
thats a point i didn't think of, if they do put it in a mag, then the production should be just as much, if not more. it would not be wise at all to have it put out less then the mag. hey red, how do you figure 275 rwhp? that would be way more than 15% loss thru the drivetrain!
post #10 of 24 Old 04-22-2002, 01:29 PM
davescobra,
His knock was against HPTV. If you watch the show often, you'll realize that his attempt at humor is pretty accurate. Those guys are dumbasses, but I still watch the shows religiously.
Herk is offline
post #11 of 24 Old 04-22-2002, 02:21 PM Thread Starter
i've seen it a few times, like so, but never pay attention to much, like so!
post #12 of 24 Old 04-22-2002, 03:32 PM
I dont know if they will void it becasue the exhaust but 100% Guarantee you that if you change the pully or tamper with the computer they will. Actaully what I heard is that when you go buy one they are going to make you sign a paper saying that you will not touch any of it. I think it will probably be ok about the exhaust-maybe- but they will be ALOT more watchful then they have been in the past. But hey if you can make close to 400rw with nothing more than exhaust that will be great- with a warranty.
Sg
01blown4.6 is offline
post #13 of 24 Old 04-22-2002, 03:37 PM
primetime's Avatar
Sg
Sg, Good to see you back! How about that information on your uncles Extreme S-281 that you were talking about and I asked you some ?'s on! Still waiting
Few cars...
primetime is offline
post #14 of 24 Old 04-22-2002, 05:11 PM
austinTX's Avatar
360 would be good, anything less is waste of a blower on DOHC.
2002 YZF-R1 12:00 Wheelies
1999 Cobra
AFS Cobra Rs Front 17x9 on 255/45 Back 17x10.5 on 285/40 R17's.
Tweecer RT
DS clutch peddle lowering device
Steeda Triax.
Kenny Brown Sports package
Bilstein Shocks\Struts (Cobra R)
K&N airfilter.
FRPP aluminum drive shaft (4602-J)
SPEC stage II clutch
Alumimum fly wheel
Steeda Tri-ax
Novi 1000 (not currently on the car)
13.51 @ 103.2 mph N/A
New Mods
2001 Head/Block due to water damage ---- (engine died 1 month later, oil pump failed)
1999 Long block from Ford now installed. (putting blower back on in about 6 months)
austinTX is offline
post #15 of 24 Old 04-22-2002, 05:19 PM
If they do dyno a true 360, that 80+ more RWHP than the 01's!!!!!!!!!! talk about a monster, I can't imagine how these are going to feel, I must have one. 4 valve power at 6000 rpm, and torque to rip the tires at 2000 rpm.
svt00r is offline
post #16 of 24 Old 04-22-2002, 05:52 PM
One word about that, ILLEGAL. The dealer can not void a warranty for these reasons. The dealer can only refuse to fix something that has failed under conditions that you have created by moding your car. Now if you come back a month later with another problem that is unrelated they will have to fix it.
81blown4.6 is offline
post #17 of 24 Old 04-22-2002, 05:56 PM
those dyno numbers sound really good.
However, what doesn't make much sense to me, is the reported trap speeds of 109-110?? Is the car's weight really that much?? Is the gearing not quite right??
I guess I was expecting more trap speed out of a 360rwhp vehicle, but I also agree with Eric, we probably just need to wait and see what actual owners achieve.
'04 cobra coupe torch red
JB VOBRA is offline
post #18 of 24 Old 04-22-2002, 07:13 PM
JB Vobra, those are some impressive times for your stock Z06. Do you know how much it weighs? and what was the 1/8 mile speed on your 7.88 run? Any dyno #'s? Just wondering.
96 Ford Cobra, PHP Stage 2 intake, All the bolt-on's, SVO Ceramic Headers, Bassani Off-Road X-pipe, Borla XR-1's, and The New 4.56's are in!
95 ZX9R Ninja 136RWHP/ 70RWTQ [email protected]
06 2WD TrailBlazer SS 6.0L LS2 395HP Stock
ALLNTRL is offline
post #19 of 24 Old 04-22-2002, 08:16 PM
Blue2003Cobra's Avatar
Well, at about 1500 miles, I'm going to dyno mine and see what it makes.. I'll keep it stock till then, then remove the 99 exhaust and put a real one on it, and see how it does..
have 2003 Sonic Blue Coupe, parchment seats on order.. I have the VIN # 1FAFP48Y23F302629 WHOOOO.. born on 23 July, shipped by convoy carrier 28 July, scheduled delivery 5 Aug..
Blue2003Cobra is offline
post #20 of 24 Old 05-03-2002, 11:21 AM
thanks ALLNTRL
the 1/8 trap was 93mph
it weighs 3050 without me and 1/8 tank gas
I just dynoed this past weekend, SAE 364.0rwhp/350.6rwtq
bonestock
JB VOBRA is offline
post #21 of 24 Old 05-03-2002, 12:03 PM
[QUOTE]Originally posted by JB VOBRA
[/QUOTE
Does Ford EVER gear anything right?
SVTCobraVert is offline
post #22 of 24 Old 05-03-2002, 02:37 PM
Well thats what the did with the Cobra R's... non the of the production ones could match the pre-production ones send for the dyno and comparison test. And this time if there low they can't get sued.... since the car would still be putting out the flywheel advertised HP. I guess we will see.
c5hardtop is offline
post #23 of 24 Old 05-04-2002, 04:56 PM
UH never knew you asked me any questions about it
Did you pm me about this? I never saw anything- so dont roll your eyes at me. If you'd like I will give you his e-mail and you can discuss it with him. I dont know very much about it - all I know is he told me he ran 11.7's with some slicks and a few mods. He lives in GA not near me. So I dont know what it really does - but I guess he could be liying to me
sg
post #24 of 24 Old 05-08-2002, 10:25 PM
Yes, we will. Soon, very soon.
97DOHC is offline
