where to buy new head gaskets? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 04-19-2002, 09:30 AM Thread Starter
turns out all the problem was a burnt out head gasket.
since there was coolant mixing with oil every where around,steam coming out of the exhaust and from the air breather hose.
at all cases where can i get a head changing kit?
even thouhg it won't do a diffrence i'll get my heads ported while there off.
PURPLEMUSTANG is offline
post #2 of 9 Old 04-19-2002, 01:00 PM
Purple Haze's Avatar
1 410 655 2000. Ask for parts, then Randy. Tell him I sent you.
Pick up some ARP headstuds too.
BTW, why wouldn't porting "do a difference?"
Good luck
Purple Haze is offline
post #3 of 9 Old 04-19-2002, 04:04 PM Thread Starter
everyone says that porting my heads(97) won't do chit.
what do you think?the guy i know is pretty good at his work.
post #4 of 9 Old 04-19-2002, 04:13 PM
There is plenty of potential in the early heads, that with a set of 2k cams should give you a good HP gain. I have a set being done by Shannon aka "The Game". It will not produce the same amount as the P&P PI heads but will come very close to the stock PI heads which is still worth while. Maybe Shannon will impart some tips to your head porter cause he is in Turkey and not really a threat to his business.
http://www.oemfordparts.com/
has the head change kit for $105 + shipping one of the best prices I have found so far.
Good luck, Dwayne
46GTSblown is offline
post #5 of 9 Old 04-19-2002, 06:10 PM
post #6 of 9 Old 04-19-2002, 08:42 PM Thread Starter
hey thanks for the info,if the p&p polished heads would be anywhere near 99+ heads then that is good enough for me.
post #7 of 9 Old 04-20-2002, 12:44 AM
Blown284's Avatar
Trader Feedback: (21)
FYI, Boss96 had a set of p&p 96/98 heads and was running very good #'s with a blower combo. With porting, there is no reason why those heads can't produce #'s like stock 99 heads I wouldn't think. But then again, port a set of 99's and ..... well you know, you'll have even more.
If funds are tight, port the heads and see what you gain.
Good luck,
Tim
SOHC/DOHC Corral Moderator
Founder,
Part-Owner,
and
'00 Ford F-350 7.3 Turdbo Diesel
'03 Droptop Cobra
'99 Cobra "10 Second Street car" (SOLD!)
Blown GT ([email protected]) ---> SOLD
'00 Camaro (Couple of bolt-ons) - [email protected] (Jun 2011).
AOL: Blown284
Blown284 is offline
post #8 of 9 Old 04-20-2002, 01:03 AM
Juiced46's Avatar
I picked up my head gaskets from www.parkwayfordga.com 1-888-Ford-SVT ask for Joe Charles. They were like $23 each around
2003 Silver Cobra Coupe
KB solid axle equipped
641rwhp 628rwtq
[email protected] [email protected] 1.49760ft missed 4th rolled thru the traps
Juiced46 is offline
post #9 of 9 Old 04-20-2002, 05:50 AM
Talking
summit racing has them in there new issue
Chris98YellowCobra is offline
