Car doesn't start like it used to - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 04-19-2002, 01:08 AM Thread Starter
x_man586's Avatar
When I got it a few months ago it would start with no problems. Now it has to crank a little before firing up. Sometimes it will fire up then die. It was just tuned up. Is there something I missed during the tune up?
2002 Lightning,2016Oxford White Mustang GT M6
x_man586 is offline
post #2 of 6 Old 04-19-2002, 03:24 AM
Run some fuel injector cleaner through it. Remember to add the the cleaner then fill up. This ensures the stuff is mixed with the gas. When is the last time you changed the fuel filter, it may have never been done from new. Also think about a new set of spark plugs and airfilter.
Dwayne
46GTSblown is offline
post #3 of 6 Old 04-20-2002, 01:07 AM
You might want to also the check the IAC (Idle Air Control). Sounds similar to the problem I had.
BlackGT99 is offline
post #4 of 6 Old 04-20-2002, 01:09 AM
Guest
spark plugs in my opinion.
Snyper5.8 is offline
post #5 of 6 Old 04-20-2002, 01:19 AM
As far as the hard start, mine went through 2 stock fuel pumps before I got smart and went with the Ford Racing 170lph pump. All better.
Start then die: I too had to change the IAC. Had no clue that was the problem, but it seemed logical. 75 beans from the dealer, and problem solved.
Try the IAC first, it's the cheaper of the two possible problems.
No Control is offline
post #6 of 6 Old 04-20-2002, 01:51 PM
I had the same thing happen out of the blue with the 99 jeep grand cherokee that my wife drives. All of the sudden it had to crank for awhile before it would start. The dealer put in a new fuel pump under warranty. On a side note, I sure wish my stangs could hook up off the line on the street like the quadra- drive does in the jeep! ha
WISCONSIN BLOZILLA is offline
