SPEC stage 3+aluminum fly wheel - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 14 Old 04-18-2002, 02:42 PM Thread Starter
Has anyone used this combonation? I manily do very little street driving and alot of Dragstrip duty. I talked to them about it and the price sounds great now just looking to see how everyone likes theres all opinions appreciated.
2008 NMRA Pure Street Champion
ALLMTR2V is offline
post #2 of 14 Old 04-18-2002, 02:45 PM
ChrisBCritter's Avatar
That is the exact combo I have. I love the clutch, it's quite strong. Chattered a little when breaking in, but that's expected with a High HP clutch. The flywheel is a lot lighter than the billet steel one I had on before, though I didn't really notice any quicker or slower revs with it. Nor did I notice that starting or stopping was any different. My 2 cents!
ChRiS
SOLD, but one day, I'll have another...
Turbocharged 2000 Gold GT | 419.7 RWHP @ 5500 @ 8 psi | 484.2 RWTQ @ 4100
Best ET:12.31 @ 116 (2.01 60') | Best MPH: 12.60 @ 118 (2.3 60') | 13.95 @ 97.5 (2.074 60')(Stock..)
ChrisBCritter is offline
post #3 of 14 Old 04-18-2002, 02:50 PM Thread Starter
Thanks Chris. Yeah he told me it may chatter some until it gets broke in. How is the pedal feel? Is it alot harder to push than stock or about the same?
ALLMTR2V is offline
post #4 of 14 Old 04-18-2002, 03:03 PM
duane v's Avatar
If you plan on staying N/A stay clear of the Aluminum FW, Billet steel FW work great on N/A cars especially the " low on torque" OHC mod engines. I had a Aluminum FW in my N/A 98 Cobra and hated it. When I broke my T-45 I saw it as an oppurtunity to switch to the Mcleod billet steel FW and it reaaly works great..
For someone like Chris's Turboed MONSTER his Stang would benefit from a Alumunum FW due to the ton of hp he's making. DA Snake boy!!!
duane v is offline
post #5 of 14 Old 04-18-2002, 03:12 PM Thread Starter
True there is about a 14lb diffrence in the two. I am just figureing launching a little higher to make up for the lost enertia. Plus it will give a little more topend. My friend Ian Mullane switched to one in his Factory Stock car and he likes his set up plus didn't hurt his 60' times and may have even picked up some et.
ALLMTR2V is offline
post #6 of 14 Old 04-18-2002, 05:22 PM
jmeiers's Avatar
Thumbs up
SPEC Stage 4 (One bad MOFO)
FRPP Billet Steel Flywheel
No chatter. Unbelievable street manners for a solid center, ceramic padded, clutch disc, that has no center shock springs in it. Lighter clutch pedal than my old FRPP/McLeoad setup too.
I beleive the reasoning that Ian is running the Aluminum Flywheel is because in Factory Stock they run on DR's. This will allow less hit on the rear tires and allow better 60fts.
If you are running on slicks, get the Billet Steel Flywheel. You want to hit the tires hard on slicks!
Later, Jason
N/A 1997 Cobra (STOCK MOTOR without any BOOST... GRANNY-SHIFTED) - RETIRED
12.14 @ 114 MPH
1.61 60ft.
306 rwhp and 301 rwtq
Best 60ft. - 1.55
jmeiers is offline
post #7 of 14 Old 04-18-2002, 05:57 PM Thread Starter
Yeah that is true, less shock to the drag radials would be better. I think I will go with the billet steal flywheel because I do run on slicks. So what kinda street manners does the stage 4 have Jason?
ALLMTR2V is offline
post #8 of 14 Old 04-18-2002, 06:58 PM
jmeiers's Avatar
Thumbs up
It is no problem on the street. In fact, my beater car just took a crap on me and I have been driving my Cobra to work for the past week without any problems.
It drives great. It is way more clutch than I need but I wanted the best out there and this is it. Plus, it leaves me serious room to grow.
Later, Jason
Also, with all the other Stages of SPEC clutches, they all chatter to some extent, just like my old FRPP/McLeod combo. Most people say the chatter goes away but my Stage 4 does not chatter.
When we first opened the box to see this clutch disc, everyone in the shop was like I am gonna hate life and said it would chatter like a biotch. Nope. It is just fine on the street and don't let anyone tell you otherwise.
12.14 @ 114 MPH
1.61 60ft.
Best 60ft. - 1.55
jmeiers is offline
post #9 of 14 Old 04-18-2002, 07:41 PM
Kick ass combo!!! This
is how mine worked out.SPEC Sucks ASS
BYBOTIE is offline
post #10 of 14 Old 04-18-2002, 07:57 PM
I put a Stage 2 in with an aluminum wheel but I have 4.56 gears and run on some notoriously slick strips. I have only run it once with the light wheel (11 lbs less than stock), but I like it fine so far. But I wouldn't do it with a 4.10 gear. I can launch at 6000 rpm with 10" ET Drags and got a 1.67 60' last week. I will launch harder this weekend and see if I can get it down a little more. I am not sure the lighter wheel will help enough after launch to make up for the lower inertia during launch. It didn't hurt any, just not convinced it helped yet.
It is fine on the street. With the gear.
Joe Lynch
99 Cobra Convert, 99GT live axle, 31 spline C-Locker, Mark Williams axles, HPM upper and lower, FMS alum driveshaft. Pro-Motion pro-shifted TKO-500 trans.
28x10/15 ET Drags on Pro-Star 15x10, 6.5BS wheels Star Stage 3S clutch, MAFterburner Plus, Aeromotive A1000-6 regulator, return style fuel system,
Aug, 2003 forged motor, HP cams, SHM valve springs, short runner intake, SCT Flasher for tuning. Best
150 shot is 10.77 at 127.8 mph in very good air. 1.35 60'.
Joe Lynch is offline
post #11 of 14 Old 04-18-2002, 10:32 PM Thread Starter
Jason- Thanks for the input I will be ordering my stage 4 with there billet steel flywheel tommorow. Just curious though how much was the FRPP flywheel and how much does it weigh? May as well go with the bad a$$ clutch huh
ALLMTR2V is offline
post #12 of 14 Old 04-18-2002, 11:17 PM
jmeiers's Avatar
I think I paid $219 for the FRPP Billet Steel Flywheel back in November of 2000.
It is actually made by McLeod but sold in an FRPP box.
Just go with the SPEC Steel Flywheel. It will be fine.
***Remember, it is one bad MOFO and you should expect that. It will hold up to whatever you throw at it and is streetable, at least to me it is. Don't expect it to be exactly like a stock clutch because it is not. I just don't want you to come back at me after its installed and say that I told you it was super-streetable or something. All my opinions on it come from someone who drives around with a C-Locker, skinnies, and no front swaybar and then goes to the track and dumps it at 7000+ rpms on slicks and then drives home afterward. A clutch like this does not bother me at all!***
12.14 @ 114 MPH
1.61 60ft.
Best 60ft. - 1.55
jmeiers is offline
post #13 of 14 Old 04-18-2002, 11:37 PM Thread Starter
*** Oh don't worry I am much the same, I drive around no A/C, turndowms skinnys, et streets, no front sway bar most of the interior out so I think I can handle the clutch***
So where would be the best place to get the Flywheel from?
Brandon
ALLMTR2V is offline
post #14 of 14 Old 04-18-2002, 11:46 PM
99mustangGT
Guest
Posts: n/a
id like to get the aluminum FW. i think it would work great in my combo, but everyone told me to stay away from it. i think im gonna get one anyway.
