Convertible Motor Mod - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 12 Old 04-16-2002, 03:52 PM Thread Starter
97GTConvt's Avatar
Anyone mod'ed their convertible motor setup to raise and lower the top faster? Our stock setup is rediculously slow, not even enough time at a stoplight half the time. If so, what did you modify? Thanks!
Lon
97GTConvt is offline
post #2 of 12 Old 04-16-2002, 06:21 PM
You're absolutely right. I always thought that my top went up and down awfully slow. I rented a newer Mustang convertible last year and noticed that the top went up and down alot alot faster than my 96 vert. Maybe just swapping in a newer motor would work.
TangerineStang is offline
post #3 of 12 Old 04-16-2002, 06:46 PM
Yes, I believe it is in the motor as well. A friend has a '98 Cobra vert and mine top goes up about twice as quick as his does. So that is only a one year difference. The only thing I could think of would be that the motors might be different.
GRN99COBRA is offline
post #4 of 12 Old 04-17-2002, 09:41 AM Thread Starter
97GTConvt's Avatar
I haven't looked at the setup. Do you think it's belt and pulley driven? Maybe then we could just change the pulley and make the motor work a little harder.
Lon
post #5 of 12 Old 04-17-2002, 10:26 AM
Mine is awfully slow aswell. Couldn't raise it all the way at a stop light, had to lower it back down. Hopefully someone will find the answer.
1997 COBRA CONVERTIBLE
BBK L/T HEADERS
O/R SHORTY H-PIPE
2 CHAMBER FLOWS
ASP PULLIES
C & L Mass Air Meter w/K& N Filter
Canton 7 Qt Street Pan w/ Windage Tray
D & D K-Member Kit w/Coil Overs
Maximum Motorsports C/C Plates
HPM Upper & Lower C/A's
Stange 10 way Shocks & Struts
Aluminum D/S
Moser 31 Spline Axles, 4.30's, everything welded
FordChip Dyno Tune 9-13-02
291.8 hp
285.9 tq
Best E.T [email protected] 106.31 mph w/ 1.74 60'
MD COBRA is offline
post #6 of 12 Old 04-17-2002, 10:31 AM Thread Starter
97GTConvt's Avatar
One way or another, I'll get to the bottom of it.. pisses me off that much LOL.
Lon
post #7 of 12 Old 04-17-2002, 12:32 PM
I remember reading somewhere that there is a new motor in the 99+ 'verts, accounting for the faster operation. Later.
jason10mm is offline
post #8 of 12 Old 04-17-2002, 12:55 PM
Maybe we all should ask Randy from Universal Ford if this is true and and get a GP on this.
BBK L/T HEADERS
O/R SHORTY H-PIPE
2 CHAMBER FLOWS
ASP PULLIES
Aluminum D/S
291.8 hp
285.9 tq
MD COBRA is offline
post #9 of 12 Old 04-17-2002, 01:07 PM
My 98 top is dang near 10x's slower than my g/f 01's top. She always want to race the tops instead of cars Help me make my top faster
GtStangRcr is offline
post #10 of 12 Old 04-17-2002, 02:57 PM
Juiced46's Avatar
I believe they are hydrolic right? Mine is awfully slow to. Maybe ill put some nitrous to it
2003 Silver Cobra Coupe
KB solid axle equipped
641rwhp 628rwtq
[email protected] [email protected] 1.49760ft missed 4th rolled thru the traps
Juiced46 is offline
post #11 of 12 Old 04-17-2002, 04:02 PM
Juiced is right- the 99+ is hydrolic the older ones are eletric. Ford thought the same thing you all do. So they changed it in 99. they have rumored from a ford rep they will in new body as well again
1999 Cobra Convertible
paxton novi2000 21#, Motec, full fuel system Upgrades ,Second Street Speed Built Block, lentech AOD, list goes on and on.....NEW ITEM SSS custom Rockers and Springs!!!!
But 880hp at crank. 705rwhp BEST's
9.84 1/4
140mph
1999blackcobra is offline
post #12 of 12 Old 04-17-2002, 05:19 PM
JP
Both pre-99 and post-99 are electro-hydraulic. The 99 up is faster due to differences in the pump, lines and hydraulic cylinders.
1997 Cobra Convertible
Triple Black
JP is offline
