Annoying squeek. pass side HELP - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 04-15-2002, 02:27 PM Thread Starter
everytime I start the car or hit any sort of bump I get a metallic sounding squeek. I figure that it might be the pass. side fender or the antenna. I have checked all the interior panels and they dont make that noise. The windshield header is a possiblilty but i cannot reproduce the souund without driving it. I dont think its suspension because why would it do it when i start the car. Please help, what could this be, its driving me crazy thanks, Oliver
99
99svt32v is offline
post #2 of 9 Old 04-15-2002, 02:33 PM
I'm thinking motor mounts have gone bad causing something else to rub??
Good luck, Dwayne
46GTSblown is offline
post #3 of 9 Old 04-15-2002, 04:46 PM Thread Starter
hmm. how would i be able to tell this? what signs should i look for on the mount itself. I was also thinking tierod. any other ideas?
99
99svt32v is offline
post #4 of 9 Old 04-15-2002, 07:27 PM Thread Starter
99svt32v is offline
post #5 of 9 Old 04-15-2002, 08:49 PM
im pretty sure you have the same problem i have... tierods...
every bump I hit either big or small I get this annoying SQeek sqeek... sounds like a mouse getting run over :-) if im not mistaken the tie rods are have no grease fittings so your options are either replacing them or if you can, inject grease into the fitting with a grease injector.
1994 SVT Cobra
MODS: Alittle of this... alittle of that.
Maddness Takes it's Toll... Please have EXACT change
iwannastang is offline
post #6 of 9 Old 04-15-2002, 09:13 PM Thread Starter
i slid under there and tried to shake the tierod and heard nothing. It sounds more like a body related squeek i dont know. motor mounts is still an option. again, the question remains, what do bad motor mounts look like, and what are the symptoms
99svt32v is offline
post #7 of 9 Old 04-16-2002, 07:18 PM Thread Starter
ttt, come on this is aggravating to no end. please help
99
99svt32v is offline
post #8 of 9 Old 04-16-2002, 07:56 PM Thread Starter
update even though no one cares. It is not coming from inside the car. I put my ear right by the pass. side front wheel and could hear it. I have the wheel off and its in the air, but i cant find it cause i cant cause the suspension to move enough. could it be the cowl plastic piece, i heard the cause a chirp/squeek noise. thanks to whoever might be nice enough to reply
99
99svt32v is offline
post #9 of 9 Old 04-16-2002, 08:30 PM
I posted this on a different thread but I'll do it here too.
I had an annoying squeak like that, it was driving me insane! It turned out to be a little bracket on the underside of the passenger fender, in the wheelwell. This little metal bracket was rubbing against the underside of the fender, making a squeaking noise. I was able to find it by using a jack to raise and lower the wheel as fast as I could. I put a ton of grease up there and it hasn't squeaked in three years.
GarrettW is offline
