what can i expect to run in the 1/4?? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 04-15-2002, 12:08 AM Thread Starter
Question what can i expect to run in the 1/4??
alrite i have a 96 cobra with stock suspension and the following mods. Can i get an estimate of my possible quarter mile times and speeds from anyone? Im just wondering what ill be running when i head to beech bend this sat nite...thanks, jared
kn filtercharger kit
steeda ud pullies
steeda triax
bbk offroad H
2chamber flowmasters
proM 80mm maf
also, what do u think ill be running after the following mods:
steeda t/a
frpp alum. driveshaft
4:10s
jareds96svt is offline
post #2 of 5 Old 04-15-2002, 12:59 AM
your car should run about the same as mine,but i am a bad driver
1fstcbr is offline
post #3 of 5 Old 04-15-2002, 02:16 AM
With really good driving people have squeaked out a 13.6-13.7 or so stock, so with equally good driving with your mods I would say a 13.3-13.5 -- The addition of the 4.10's is good for another .2 give or take. I don't know anything about the aluminum driveshaft, and some people swear by T/A's while others claim they do next to nothing. I would say with those mods and good driving the car is capable of a 13 flat and if you threw some Nitto DR's on there or something similar to solve traction issues you could scrape 12's. Just my thoughts!
Immortality is offline
post #4 of 5 Old 04-15-2002, 01:52 PM
I would say somewhere between 13.7 and 13.8 if you are a good driver and if you get good traction. There are also so many other factors like temperature and things, but you should have no problem running high 13's with that car and those mods. I also found that when I put in the off-road H I seemed to lose a little low-end on the car, so between 3 and 4 grand is where the car should really start pulling, just in case it feels a little sluggish off the line. As far as the other mods you're considering out of all of those I think gears will make the most significant difference in track times, but you will have to do something with your tires or you will get absolutely no traction.
Cobragirl96 is offline
post #5 of 5 Old 04-15-2002, 02:12 PM Thread Starter
yeh im afraid ill have to get some slicks soon as i bolt in my 410s cause i hear they dont hold traction too well..dang! So what kind of slicks are people running, i have stock cobra rims that im gonna use for the track once i get my Y2Ks put on in a week or two..jared
