Plugs out, what gap???? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 04-14-2002, 07:16 PM Thread Starter
I am putting in Motorcraft AWSF22C plugs as we speak. They are gapped .042 out of the box. Is that fine on a stock 98GT motor? Need help quick!!
Amherst is offline
post #2 of 7 Old 04-14-2002, 07:20 PM
stock gap should be .055
HAWAIIAN_98SNAKE is offline
post #3 of 7 Old 04-14-2002, 07:29 PM Thread Starter
So your saying that I should gap them at .055, or the plugs should have come from Motorcraft at .055?
Amherst is offline
post #4 of 7 Old 04-14-2002, 10:29 PM
re-gap them.
post #5 of 7 Old 04-14-2002, 10:36 PM Thread Starter
Thanks dude! Swap went well once I got the #4 plug out! Car drives noticibly better. I will know tomorrow if the mileage is better.
Amherst is offline
post #6 of 7 Old 04-14-2002, 10:41 PM
before you put the plugs in make sure you replace your heads with 99+ PI heads. and also some never-seize on the plug threads if you have copper plugs - > this will maximize your performance allowing you to get the best bang for your spark, and eliminate troublesome removal of your plugs in the future.
never-seize/anti-seize everything!! LOL!!
Gap them @ .54 for N/A, .35 for a power adder - is the rule of thumb I always follow.
SilverStanger is offline
post #7 of 7 Old 04-14-2002, 11:01 PM Thread Starter
Yep, used the anti-seize. Do does the anti-seal (not the singer help with compression, or to keep things sealed?
Amherst is offline
