head/cam install problems - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 04-14-2002, 08:15 AM Thread Starter
well, i installed my dta ported heads and crane 550 lift cams, went to start the car and it would not fire. did a compression test, and all the pass side cylinders posted 175psi. did the drivers side, and the highest i got was 40psi. looks like i got a bad cam. i'm gonna call crane, and hopefully they will fix this problem. i installed my stockers back in the car for now, what a pain this has turned out to be. anyone else have an experience like this?
DD: 2004 Grand Cherokee Freedom Edition with 4.7 HO V8
Auto-x slut: 1999 Miata setup for street prepared
Wanted: Fun V8 musclecar!
96gtmustang is offline
post #2 of 9 Old 04-14-2002, 10:40 AM
rigcol's Avatar
Unhappy .........
Dude, that sucks! I'm in the process of getting mine together.... after all this time I'm hoping it all works out...
rigcol is offline
post #3 of 9 Old 04-14-2002, 10:54 AM
so does it run fine with the stock cams?
fordcountry1 is offline
post #4 of 9 Old 04-14-2002, 02:17 PM
So is the car running fine with the stock cams? If so did you make sure you had everything done right on the driver side when installing the Crane Cams. I have been throught this process many of times and never had any problems.
NMCA MS 10075(Derek Downs)
Thanks to:
KC Engines
D2KStang is offline
post #5 of 9 Old 04-14-2002, 07:25 PM Thread Starter
well, i got her back together with the stock cams, and it runs great(measured @175 psi on all 8). the ported heads make a difference. now i get to work out my problems with crane, this will not be fun.
post #6 of 9 Old 04-14-2002, 08:23 PM
98GTfromGA's Avatar
when did you place your order with TheGame?
John
98GTfromGA is offline
post #7 of 9 Old 04-15-2002, 02:01 AM
I sent in my deposit on Feb 4th
NiagaraGlenn is offline
post #8 of 9 Old 04-15-2002, 09:33 AM
Boss96's Avatar
Jason, you may well have a problem with the cams, you need to check the lash or space between the rocker and lifter tip when the lifter is collapsed. ( I know the correct term is not "lifter and rocker") If the cam was not ground correctly you may have the valves hanging open using the spacers Crane gives you to put on the valve stems. I had this problem with the first set of cams from them, they had to re-do the cam to fix it.
Bob
96GT with lots of mods
Boss96 is offline
post #9 of 9 Old 04-15-2002, 02:25 PM Thread Starter
i'm gonna send them back, and hopefully they can fix the problem
