questions about fuel injectors etc - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 04-12-2002, 11:28 PM Thread Starter
how easy is it to replace the injectors on a '00 gt 5sp?should i up grade them, with a stock car? would there be any benefits?Im asking because i will be buying a mass air and would hate to have to buy another(mass air)in the future since you buy them calibrated for the injectors.Just trying to save money and think ahead.
12amracer is offline
post #2 of 6 Old 04-13-2002, 01:32 PM Thread Starter
post #3 of 6 Old 04-14-2002, 09:22 PM Thread Starter
post #4 of 6 Old 04-14-2002, 09:35 PM
Very easy to replace however you don't need them unless you are adding a power adder like a S/C or Nitrous and then you will need to get a chip for them to work correctly.
Save your money and get a timing adjuster, pulleys and/or gears.
GT2KDave is offline
post #5 of 6 Old 04-14-2002, 09:46 PM
if you can get more air into your engine to use the gas... super/turbo/nitrous/
98toplesscobra is offline
post #6 of 6 Old 04-15-2002, 12:03 AM
GT2KDave is right, it is completely pointless to upgrade your injectors and MAF unless you go with heavy mods like:
-boost
-nitrous
-N/A heavy mods like heads, intake, exhaust, cams, long tube headers, etc.
Don't even buy an aftermarket MAF for your car. THE STOCK MAF IS JUST FINE WITH THE STOCK INJECTORS. The MAF companies won't say that of course. Send me the money instead. The stock GT injectors are good for up to 300 HP.
esandes is offline
