Difference between T-45 and TR-3650?? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 10 Old 04-12-2002, 04:56 PM Thread Starter
What are the differences in these trannies. Less problems in the newer TR-3650? Please inform me... thanks...
Tur*bLu is offline
post #2 of 10 Old 04-12-2002, 05:14 PM
TB--good question--I thought I was just stupid but I would like to know also-- posted this to keep it at the top and maybe some transmission expert can help us ratman
ratman is offline
post #3 of 10 Old 04-12-2002, 05:20 PM
Real easy go to tremecs websight. They will give you the complete breakdown on each.
SILVER BULLET2 is offline
post #4 of 10 Old 04-12-2002, 05:24 PM Thread Starter
CMAGLIO- from stangnet.com says...
this is what i can extract of any importance from the article:
-TR3650 has 360lb/ft torque capacity vs. T45 325lb/ft
-No speedo gear in TR3650 (I thought late model T45 had no speedo gear as well)
-Reverse is synchonized
-TR3650 new "multi-rail" shift linkage, i guess a little smoother than T45 supposedly
-TR3650 is filled with premuium sythetic ATF (mobil1) as the factory oil as opposed to Dexron III in T45
-Drain plug is on the bottom of the TR3650 vs. the side of the T45
Says the switch from TR3650 to T45 is a total bolt on affair with only minor modifications to the back-up lamp switch pigtail, and if it is a pre 99+ mustang the speedo needs to be converted to electronic instead of gears.
This is the title of the article "Shifting Evolution: TTC-Tremec's new TR3650 5-Speed combines the shift-ability of the T45 with the durability of the legedary TR3550"
In the real world though I have heard of some serious problems with the TR3650 including some crappy 1st gear lockout above a certain MPH and other annoyances like that... I have also heard it has not proven itself mroe durable than the T45 but who knows...
also.
may I have the link to Tremecs web site...???
Tur*bLu is offline
post #5 of 10 Old 04-12-2002, 06:07 PM
LaserPony02's Avatar
www.ttcautomotive.com
I don't have any problems with the 3650 in my 02GT. Some peeps try to downshift into first but most manuals won't go into first gear above a certain speed. Peace
P.S. Their website really needs to be updated. Nonetheless there is some useful info on the site.
2002 Laser Red Premium GT Coupe.
Five speed.
K&N in the box. Air silencer removed.
Gone but not forgotten:
1967 Mercury Cougar XR7. 289, C4, nine inch rear.
LaserPony02 is offline
post #6 of 10 Old 04-12-2002, 06:36 PM
THANKS for info TB-- made a copy very good summary! WOW somebody finally put a drain plug on the bottom!!! I bet it took 4 years of engineering school to figure that one out--when I was 15 yo I asked my dad why the plug was on the side instead of the bottom and he kind of looked at me funny!!
ratman is offline
post #7 of 10 Old 04-12-2002, 09:01 PM
PritchSVT97's Avatar
Trader Feedback: (109)
This one is EASY....
The difference between the T-45 and TR3650 is that it will take just slightly longer to blow the 3650 up versus the T-45...
They are both crap, the TR3650 is just in a bit better package.
T-45
TR3650
'97 Cobra...Terminator in SN clothing.
3.3L Lysholm, Aluminator, T56, IRS.
PritchSVT97 is offline
post #8 of 10 Old 04-13-2002, 01:23 AM
There WERE some shift fork (1-2) problems in the first ones put in the later half of 2001.
other than that there have only been only a few total blow-ups and melt-downs that i've seen (and i look constantly on this and other boards, and i work at a dealer and check for them).
Only time will tell if it is better; it is still a relatively new unit.
the 2002 model year is only a few months away from turning into 2003 model year and there haven't been any apparent defects or major failures that i've seen.
"I never quite know whether Moore is as ignorant as he looks, or even if that would be humanly possible."
Christopher Hitchens
June, 2004.
fixer is offline
post #9 of 10 Old 04-13-2002, 01:28 AM
Fixer, I agree, I've talked to a couple people who had complete failure with the 3650, but for the majority it seems to be pretty tough, no major problems. Maybe just a bad batch in some 2001s. I work mine pretty hard, still tight, maybe a little noisy, but no probs.
There was this guy at the track tonight with a 5 speed 5 liter running like low 11s aborting each run at some point. It's pretty impressive to see a 10 second 5 speed car, no question. I'm wondering what kind of tranny they are running.
Jeff
nomore4bangers is offline
post #10 of 10 Old 04-13-2002, 01:31 AM
Jeff
ususally its either a tremec TKO or a Tremec 3550.
June, 2004.
fixer is offline
