rear end girdle question - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 04-11-2002, 03:00 PM Thread Starter
I have a Granatelli motorsports rear end girdle on my 2000 gt and ever since I put it on I have noticed a "clank" when I turn or hit even the smallest bump. Is the sway bar hitting the cover? It is real close to it but I haven't heard of not being able to use your stock sway bar with a rear end girdle. Any input on if this is the problem or if you have had a similar problem would be helpful. Thanks
jckracing is offline
post #2 of 4 Old 04-11-2002, 03:16 PM
Just get under htere and take a look if it is hitting you will see nice bright aluminium where it is touching. All you will have to do is clearence the cover with a file/grinder where it is touching.
46GTSblown is offline
post #3 of 4 Old 04-11-2002, 05:36 PM
Do you have the pre load bolts with it? If so, how hard did you torque them down? You shouldnt hear ANY noise coming from it.
Venomous Mofo is offline
post #4 of 4 Old 04-11-2002, 11:06 PM Thread Starter
Yes it has preload bolts and i did not torque them down too much just enough to be snug. I don't see any shining spots on the cover but I will look a little closer tomorrow. Thanks for the help.
