Should you change gear oil after 500 miles?? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 04-10-2002, 12:31 AM Thread Starter
Subject pretty much says it all. I'm having gears installed Friday and the guy said he's just putting in standard gear oil not synthetic because I should change it in 500 miles anyways. Do you really need to replace it after the swap? Should I just use synthetic now and not worry about it? Whats the normal interval for changing the oil if its standard vs synthetic? Thanks
65 Coupe with 289/C4 (302/T-5 swap in process)
Previous Stangs
Black 89GT Hatch with built 302, sold 7-2001
Chrome Yellow 99GT, sold 8-2003
gr99gt is offline
post #2 of 5 Old 04-10-2002, 01:31 AM
you should so that you can get all the little metal shavings that might be floating around from the new gears out. it's really easy to do. just fill it back up with redline gear oil which already has the friction modifer in it so you don't have to add anymore.
stangin' is offline
post #3 of 5 Old 04-10-2002, 10:53 AM Thread Starter
Thanks. Just wanted to be sure.
Is there any break in needed on the gears? I've noticed alot of mixed ideas in the archives.
Previous Stangs
gr99gt is offline
post #4 of 5 Old 04-10-2002, 10:59 AM
TxSnakeCharmer's Avatar
Disregard, I missed part of your explanation.
TxSnakeCharmer is offline
post #5 of 5 Old 04-10-2002, 11:19 AM
Michael Clements's Avatar
Yes. The gears should be heat cycled. At first, drive slowly and for short distances, stopping to let the diff cool off. Gradually build up higher speeds and longer distances until after 500 miles the gears are supposed to be broken in. In reality, the gears are probably broken in before that point. The important thing is when they're brand new, don't drive at hard acceleration, high speed or long distances. You must drive easy & stop every few miles to let the gears cool off.
1999 Panoz Roadster; autox prepped with various bolt-ons and weight reduction
[We're moving out of state and the Panoz is currently FOR SALE]
Michael Clements is offline
