Cheapest Bottle Warmer? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 04-09-2002, 09:19 PM Thread Starter
Whats the cheapest one? Im going to run it through my fog light switch... has anyone sucessfully done this?
Hocke0233 is offline
post #2 of 6 Old 04-10-2002, 03:59 PM Thread Starter
post #3 of 6 Old 04-10-2002, 05:15 PM
makemeknowit's Avatar
Cheapest isn't always the best idea. Ask the ones on here about the NX transducer/warmer. It turns the bottle warmer on below 900psi and shuts it off around 1050psi. It will work with any brand of warmer. NOS's thermostat operated crap is just that, crap. I had to bypass my 'stats to get my pressure where it needed to be. The NOS 'stats wouldn't even let the pressure get to 900psi before shutting off! I picked up a transducer on ebay but have yet to install it, but everyone here who has it that I have talked to loves it. Also, I've read on here that the fog light switch can't handle the amps, fwiw.
now voters are starting to wake up and hope there is no change
makemeknowit is offline
post #4 of 6 Old 04-10-2002, 05:26 PM
You can get the compucar one for around $60.
nosmod2v is offline
post #5 of 6 Old 04-10-2002, 06:19 PM
I think the fog switch is ok. The heater has a 30 or a 60 amp relay on it. So all the switch is doing is turning the relay on.
willrace4food is offline
post #6 of 6 Old 04-10-2002, 08:26 PM
Juiced46's Avatar
Cheaper is definetely not better when it comes to bottle heaters. I thought the same thing and bought the NOS heater The thermostat doesnt work right, i would have to bypass it to get anything over 875psi, it sucked!! Spend the extra $70 or however much it is to get the NX warmer, its MUCH better. Willrace4food has it and its awsome compared to the NOS. If you want to save a big headache go with the NX. I beleive its around $180, the NOS one was about $120.
2003 Silver Cobra Coupe
KB solid axle equipped
641rwhp 628rwtq
[email protected] [email protected] 1.49760ft missed 4th rolled thru the traps
Juiced46 is offline
