Any problems with Lowering 97 Cobra with 18inch rims - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 04-08-2002, 06:07 PM Thread Starter
I have the 18inch 2000 Cobra R's and I want to lower the car 1.5".
I have 285/35 Nittos all around.
KeithCobraUH is offline
post #2 of 5 Old 04-08-2002, 06:22 PM
Tight fit , I've had to roll the lips of the rear fenders and install rack limiters on the front.
scottbeer is offline
post #3 of 5 Old 04-08-2002, 06:48 PM
I'm only running a 275/35 18 so I didn't have to roll the fenders. But I did use the Steeda steering rack limiters to keep the wheel from rubbing the swaybar .
Crystal White 98 Cobra
[email protected]
Steeda G-Trac Stage 3, Steeda U/D, Steeda Tri-Ax, Steeda T/A, UPR power pipe, Perf Dist Screamin Demon Coils and Live Wires, FRPP Alum d/s, FRPP 4.30's, DR Gas off road X, 2 Chamber Flows
Steve's 98 Cobra is offline
post #4 of 5 Old 04-09-2002, 11:04 AM Thread Starter
My car rubs the sway bar on tight turns.
I guess I will look into to it more.
post #5 of 5 Old 04-09-2002, 11:42 AM
I'm running BBS RK wheels. No problem (even with front Griggs stuff moving wheels forward and out a little) with front 18X8.5" with 25MM offset (about 5 3/4" BS) with 245X40X18 tires. On rear 18X10 with 20 MM offset (about 6 3/8" BS) with 285X35X18 tires, if I were lowered more than the rear 95 R spring drop of 1 1/4", I would have a problem with wheel well rim.
Ralph Greene
Ralph Greene is offline
