Installing a TB - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 04-08-2002, 05:57 PM Thread Starter
DS97Cobra's Avatar
Installing a TB
I am considering switching TB on my car. I currently have a Ford Oval TB.
Is there anything I need to know when doing this or is it as simple as it seems?
Any gasket issues?
DS97Cobra is offline
post #2 of 9 Old 04-08-2002, 07:19 PM
I am thinking that TB means throtal body? If so, you do need a new gasket and it's just 4 - 8mm nuts that hold the throtal body on. Just pull the old one off and bolt your new one in place and enjoy.
If it's not a throtal body your asking about, at least now you know how to put one on if you every have the desire.
orange peel is offline
post #3 of 9 Old 04-08-2002, 07:28 PM
DLF
He probably meant throttle body
98 Laser Red/Black Cobra Coupe (T56/IRS)
12.483 @ 110.94
95 Pearl White Thunderbird SC 5spd
12.879 @ 106.66
DLF is offline
post #4 of 9 Old 04-08-2002, 09:10 PM Thread Starter
DS97Cobra's Avatar
Yes I meant throttle body.
So it is that simple, good!
post #5 of 9 Old 04-08-2002, 10:38 PM
TB INSTALL
Use a new gasket!
2006 Premium GT Convertible
Screaming Yellow, Black Top
Black Leather
18" "Fanblade Wheels"
Interior Upgrade Pkg.
Side Airbags
Soft Boot
Shaker 500 Audio System
5 Speed
CORSA Performance exhaust
GOLDENPONY is offline
post #6 of 9 Old 04-08-2002, 10:56 PM
Guest
if you buy the FMS 70mm it comes with a new gasket. Gives great throttle response.
Snyper5.8 is offline
post #7 of 9 Old 04-09-2002, 12:24 AM
Mavi99GT's Avatar
The BBK 70mm TB is also an excellent choice. -Just recently switched to it. It comes with the gasket also. The install takes about 20 minutes. -Hardest part was getting the Throttle position Sensor off of the old TB because it had corroded slightly. I'm now getting much better throttle response over stock - I can really feel it.
Mavi99GT is offline
post #8 of 9 Old 04-09-2002, 12:32 AM
The TB swap is easy. Unless you shred the gasket you can reuse it.
Mark Worthington is offline
post #9 of 9 Old 04-09-2002, 11:11 AM
Guest
the FMS one comes with sensor already attached making it an even better throttle body than the other aftermarket ones. BBK has been known to break.
