new triple pickup quadrant weirdness... Help! - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 04-08-2002, 04:22 PM Thread Starter
I just installed a new UPR triple quadrant and cable.
My pedel effort is way more than it use to be. I mean, this is serious! It really takes a lot of pounds to push in the clutch. It also only takes about 1" to 1 1/2" to fully engage the clutch. is this right? I have played with the new firewall adjuster to no avail. Also, what does the other pickups do? I am on the last pickup.
962v-stang is offline
post #2 of 5 Old 04-08-2002, 06:03 PM
Thumbs up
Go back to your stock cable. The same thing happend to me when i did the quadrent change, So I went back to the stock cable and everything went away and the pedal effort was even less then the stock quad. Hope this helps any.
BLK 97 SVT is offline
post #3 of 5 Old 04-09-2002, 11:48 AM Thread Starter
I will try it. what a pain.
post #4 of 5 Old 04-09-2002, 02:23 PM
upr
mine does the same thing but it gets better when the car is warm. i put some tri-flo in (liquid tefflon) and it made it a little better. i would switch back to the stock cable but im lazy.
mikesslow50h is offline
post #5 of 5 Old 04-09-2002, 07:27 PM
if you are using the last, longest pickup point then you have less leverage than the first point.
James
The Internet's 1st Mustang Enthusiasts Club
IslandVobra is offline
