new02- which mod to go with 1st? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 14 Old 04-07-2002, 10:10 PM Thread Starter
new to the mustang scene. what mod first? pulleys, cold air, mass air meter, or h-pipe with cats? or something else?
light-stang is offline
post #2 of 14 Old 04-07-2002, 10:54 PM
The first small list of affordable but effective mods are:
-K&N filter
-Remove your silencer (that rubber thing that goes in the fender)when you replace your filter
-Get a 3.73 gear as your differential
If you wish to stick with simple inexpensive mods and nothing else be sure to get a chip like Diablo or even Hypertech. This will help greatly if you have an auto.
Cheers
esandes is offline
post #3 of 14 Old 04-07-2002, 11:09 PM
If you don't already have an aftermarket shifter, I suggest that. Makes a ton of difference. You will not regret it.
2001 Mineral Grey GT, Tri-Ax, Magnaflow Cat-Back, Bullitt Suspension, Steeda LCA's, more to come since it is now paid off....
MinGrey01GT is offline
post #4 of 14 Old 04-08-2002, 08:53 AM
1. shifter
2. subframe connectors
3. gears (3.73 or 4.10)
Gary01GT is offline
post #5 of 14 Old 04-08-2002, 09:54 AM
Fast Eddie 2k1 GT's Avatar
How much do you want to spend?
S/C is the best mod. If too much money then:
3.73 or 4.10 gears
aluminium D/S
If auto then stall convertor and chip to change shift points. If manual, chip not worth it unless you want to correct speedo with it.
If you get an after market shifter be sure to test drive a car with one in it. A few people are unhappy with the way they feel.
Now after saying that: Do you want hp gains, appearence mods, or change the exhausts sound? Search the archives there have been plenty of questions on all the above.
3X black premium 2k1 GT 5 speed ragtop
Drive Train:
FMS 3.73 gears, Vortech SQ, AFM powerpipe, FMS aluminum D/S, Steeda shifter, 80 mm MAF, Steeda Fuel pump, SnowPerformance water injecton, BBK 75MM TB, C&L plenum, SCT chip
Wheels/Tires: 10th anniversary Cobra, Nitto ZR 275 x 40 x17
Suspension:
TKO 5 way (years 87 to 93 for 94+ lowered stangs), Vert Eibach Pro Springs, offset rack bushings, Steeda c/c plates, Steeda subframes w/cross brace, Steeda X2 balljoints and bumpsteer
Interior:
99 Mustang A-pillar covers, Autometer A-Pillar gauge pod, Autometer FP and boost gauges, 03 Cobra headrest
Exchaust:
Steeda catback (Borla) wholesale price
RWHP/360 RWTQ/360 SAE corrected
Very conserative tune.
69 Maroon Torino GT Fastback
Eddie
Fast Eddie 2k1 GT is offline
post #6 of 14 Old 04-08-2002, 09:59 AM
Originally posted by Gary01GT
1. shifter
What exatly do subframe connectors do?
Yoop33 is offline
post #7 of 14 Old 04-08-2002, 10:07 AM
When you all change the gears does the car run harder on the highway? I just traded my F-150 4.2l 5 speed for this 2002 GT and i like how when im on the highway running 70-80 the rpm's are way low. In my truck it ran alot harder and was loud. That rearend swap sounds good and all but how hard does it run the car at like 80 mph? When it gets nicer out i make hour and 15 min trips to the lake everyweekend. Just wonder couse that sound like a good mod after i get my new exhaust but not if it makes the stang to low geared.
1/2 bent is offline
post #8 of 14 Old 04-08-2002, 10:47 AM
Very first mod to any 5sp car should be a shifter. After that, I'd say gears and drag radials.
2012 Silver GT, M6, Brembos, 3.73s, Lethal OR-H, K&N, tuned
Marc00GT is offline
post #9 of 14 Old 04-08-2002, 11:06 AM
COBRA90GT's Avatar
Lightbulb
I waited about 9 months after I bought my mustang to put in the steeda tri ax shifter, but now wish I could have installed it right on day one!
DO get the shifter ASAP! (a great mod IMHO)
Then, proceed to do the rest..... gears, new intermediate pipe, K&N air filter, maybe a CAI, suspension, etc, etc... goodluck with it
'01 Cobra Coupe From 6.01 - 9.15
'94 Cobra Coupe From 9.09 - 6.11
'14 F-150 Raptor SCAB Deliv 3.14
COBRA90GT is offline
post #10 of 14 Old 04-08-2002, 11:18 AM
Mavi99GT's Avatar
Gears. 4:10s if you plan to stay NA or 3:73s if you plan to SC.
(NA=Naturally Aspirated)
(SC=Supercharged)
Mavi99GT is offline
post #11 of 14 Old 04-08-2002, 12:29 PM
I can give you the order I did on my '02 GT.
1. Immediately, tri-ax shifter. It can save you from bending the forks in the tranny.
2. Subframe connectors and Eibach pro-kit springs and shock tower brace. (Always wanted to know how a Mustang would fare if never allowed to twist)
3. Longtube headers, h-pipe with cats, and cat-back exhaust.
4. 4.10 gears (runs about 2700 rpms at 80 on the highway)
*** At this point, had good-running car with no hassles.
5. C&L meter and 70mm throttle body. (Have SES light since installing meter - haven't figured out why yet, so I haven't put the throttle body on yet. No dtc code stored, no driveability issues other than the poor idle its had since new.)
CraigO is offline
post #12 of 14 Old 04-08-2002, 12:35 PM
Nate Johnson's Avatar
(1) Shifter (2) K&N (3) Steeda Timing Adjuster (4) underdrive pulleys (5) 3.73 gears and a bigger throttle body.
2008 Bullitt 3091!
Nate Johnson is offline
post #13 of 14 Old 04-09-2002, 09:20 PM
1. shifter 2. offroad h pipe 3 gears 4 timing adjuster 5 tires
dehoass is offline
post #14 of 14 Old 04-14-2002, 11:28 AM
dehoass,
I am curious to why you are switching out your 4.10's for 3.73's?
Ponylova is offline
