Installed Modified 96-98 4V Intake And IMRC Deletes Today! - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 12 Old 04-07-2002, 10:07 PM Thread Starter
Thumbs up Installed Modified 96-98 4V Intake And IMRC Deletes Today!
Finally finished up the intake/deletes and got them on the car today. Here's a link to some details>>>
http://www.flash.net/~ivc1/cobra/manifold.html
So far, so good. Driveability is pretty much unaffected. Although, it took a little tuning with the EEC Tuner to get the cold start driveability back to where it was prior to the mods. Unfortunately, it's raining so I'll have to wait to do more tuning and try a few WOT runs. The short drive I did make, I immediately noted that it revs to 7K much quicker/freely. As best as I can tell, it pulls at least as hard as before below 3250 RPM. If it did lose some low end power, it's not much.
Hopefully, I get it dialed in SOTP this week and make it to the dyno Friday.
More later...back to the laptop to look at some Autotap data and make some EEC Tuner files to try tomorrow.
Blown46Cobra is offline
post #2 of 12 Old 04-07-2002, 11:52 PM
DLF
I'd be extremely interested in the EEC-Tuner changes you've made, other than the IMRC delete (which gets set to 0, correct?), as I'm planning to go to deletes myself.
98 Laser Red/Black Cobra Coupe (T56/IRS)
12.483 @ 110.94
95 Pearl White Thunderbird SC 5spd
12.879 @ 106.66
DLF is offline
post #3 of 12 Old 04-07-2002, 11:55 PM
G98Cobra's Avatar
Cool
What is the point in doing these deletes? What are they and are there advantages to having or not having them?
I have a 98 also....
98 Black Cobra
4.10's
K&N Filter
BBK LT's
BBK O/R H-pipe
PRO-M 87mm MAF
Magnapack Catback
Steeda Underdrive Pullies
SPEC Stage II Clutch
SPEC Aluminum Flywheel
SPEC Pressure Plate
JMS Custom Tune Chip (Chris Johnson Tune)
293.7 hp
288.8 trq
G98Cobra is offline
post #4 of 12 Old 04-08-2002, 12:11 AM
austinTX's Avatar
Did you get rid of the cold engine detonation (noise)?????
2002 YZF-R1 12:00 Wheelies
1999 Cobra
AFS Cobra Rs Front 17x9 on 255/45 Back 17x10.5 on 285/40 R17's.
Tweecer RT
DS clutch peddle lowering device
Steeda Triax.
Kenny Brown Sports package
Bilstein Shocks\Struts (Cobra R)
K&N airfilter.
FRPP aluminum drive shaft (4602-J)
SPEC stage II clutch
Alumimum fly wheel
Steeda Tri-ax
Novi 1000 (not currently on the car)
13.51 @ 103.2 mph N/A
New Mods
2001 Head/Block due to water damage ---- (engine died 1 month later, oil pump failed)
1999 Long block from Ford now installed. (putting blower back on in about 6 months)
austinTX is offline
post #5 of 12 Old 04-08-2002, 01:32 AM Thread Starter
DLF- Because I've removed the IMRC controller, I set the IMRC opening rpm to 8500. I've read that setting it to zero would result in a check engine light as the controller is deleted. I'll reply with more details once I evaluate some changes more thoroughly. Right now, I'm focusing on timing, manifold volume and some of the fuel-related parameters.
William - As I thought, it was a little bit of tip-in detonation. Yes, I've taken care of it.
G98Cobra - The deletes contribute to improved airflow.
post #6 of 12 Old 04-08-2002, 12:36 PM
Hey - cool idea. Although I don't have the same setup, what are you using for computer tuning?
2016 GT, Perf/Prem, ruby red.
99 Cobra ebony, blk int. #1762/4040
86GT, 88LX 5.0, 95GT
ctfren ch @ iClo ud. n e t (remove spaces)
lo pony is offline
post #7 of 12 Old 04-08-2002, 03:39 PM Thread Starter
I'm using an EEC Tuner.
post #8 of 12 Old 04-08-2002, 04:08 PM
Thumbs up nice
I'll have to talk to you about it Next time we meet up. I have been thinking about doing them since i dont have to worry ot much about loosing low end power
TJSCOBRA is offline
post #9 of 12 Old 04-08-2002, 07:57 PM
VenomousCobra's Avatar
Good info on the site. Need more information on how you did the shaft removal on the IMRC plates and how you went about expoxing -sp? the shaft holes up. Did you run expoxy throughout the shaft between cylinders, or just plug each side of the shaft hole? I'm thinking about doing a very similar thing to mine, and could use all the help that I can get. I'm running a KB, so I don't really need the IMRC plates.
Jeff
97 Cobra. Bassani catted X-pipe , CDC Side exhaust kit, 4.10's, Upgraded 11" 26 spline FMS clutch T56 Magnum 6 speed. Forged Internals, JE 9cc Pistons, Vortech V-1 S-Trim 3.33" pulley, AFM PP SCT BA2400, 55lb/hr Inj. 501.71HP/415.4TQ on Mustang Dyno
Jeff
VenomousCobra is offline
post #10 of 12 Old 04-08-2002, 10:54 PM Thread Starter
Jeff
I'll add some details on making the deletes and repost a link to my IMRC page. I should have it uploaded by mid-day tomorrow.
post #11 of 12 Old 04-11-2002, 12:03 AM Thread Starter
Jeff
As promised, I've added additional details on converting the OEM plate assemblies to deletes.
http://www.flash.net/~ivc1/cobra/imrcdel.html
Let me know if you have any questions.
post #12 of 12 Old 04-11-2002, 03:16 AM
awesome write up, thanks!
Jeff
Jeff
