15" rims w/drag radials - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 13 Old 03-26-2002, 11:27 AM Thread Starter
Guido in Da Cobra's Avatar
I want to put on 15 inch rims (to help with my weak 4.10 gearing) with nitto drags. What size rim will clear the brakes? i'm thinking some pep boy specials maybe. Also what drag radial size will fit these rims...remember i wanna keep the overall tire size smaller then stock.
thanks
Mikey
1998 Black Cobra Convertible- FR500 Stuff, T56, MM Suspension. -Garage Queen-
1998 Blue GT- Loud Pipes, MM Suspension. -Daily Beater-
Guido in Da Cobra is offline
post #2 of 13 Old 03-26-2002, 11:57 AM
There are very few 15 inch rims that will clear the Cobras bigger brakes. I own a Bullitt which has the Cobras brakes. I recenty did alot of research finding a cheap rim "15" inch that would fit. The rims I bought is the American Racing Equip rims. The part # is ARE-767. Backspacing is 4.75. Tires are the BF goodrich drag radials and they hook. You can order the rims from Summitt. The cost was 83 bucks total price for both rims delivered to the door.
Hope this helps.
SILVER BULLET2 is offline
post #3 of 13 Old 03-26-2002, 12:34 PM
docdave22's Avatar
Trader Feedback: (18)
I had to grind the piss out of my calipers for my welds.
2012 5.0 with TVS2300
docdave22 is offline
post #4 of 13 Old 03-26-2002, 12:53 PM
I am pretty sure the ARE rims will fit. I run them on my GT, but I thought the rear brakes on the GT and Cobra were the same.
You can get both the tires and rims from summit.
SliderGT is offline
post #5 of 13 Old 03-26-2002, 01:22 PM
Also...You won't find any 15" DRs that are less overall diameter than stock tires.
Ralph Greene
Ralph Greene is offline
post #6 of 13 Old 03-26-2002, 01:34 PM Thread Starter
damn...then what about 16"
or bfgoodrich instead of nittos?
post #7 of 13 Old 03-26-2002, 01:36 PM Thread Starter
looks good dave
i see you got track numbers on your car
what did it run?
juice or n/a?
post #8 of 13 Old 03-26-2002, 01:38 PM
I've seen some very good times with BFG 255X16 DR's on stock 16" wheels. They're about 26" tall, but no problem.
Ralph Greene
post #9 of 13 Old 03-26-2002, 01:42 PM Thread Starter
well the big reason i wanted a lower overall tire diameter was because i think i shift to 4th too close to the traps (damn 4.10's) and rather then spend another $400 for a gear swap i thought i'd just try some smaller wheels.
i'm not looking to get a 1.6 short time. a 1.9 would make me happy for now.
post #10 of 13 Old 04-13-2002, 06:41 PM
Fast96SVT's Avatar
I have gotten 1.8s on Nitto 17s. I ended up running a12.8 @ 108 with skinnies on front
Blue and Copper 04 F150 Screw -The Daily Beater
White 96 Cobra #705 out of 7496 -Way to much to list! 850HP coming soon...
Red 93 5.0 - Pretty stock "Thank You DAD!"
Fast96SVT is offline
post #11 of 13 Old 04-13-2002, 10:06 PM
docdave22's Avatar
Well, that wasn't a good night. (at the track) I had not figured out the nitrous problems that I was having, and I wasn't concentrating on a n/a time. I would try to spray, and I would have problems. I only made a few passes and the tire/wheel setup wasn't as sticky as I had hoped so I was spinning pretty bad out of the hole. I almost burned my clutch up, the bolt came off my alternator pulley. It was just one of those overall bad nights at the track. I think that the best time I ever got was like a 8.70. I haven't been back since I got the nitrous working (Finally).
post #12 of 13 Old 04-14-2002, 09:50 AM
Fast96SVT's Avatar
COOL, Glad to hear you got it taken care off.
post #13 of 13 Old 04-14-2002, 10:45 AM
Slider GT is correct. The ARE wheels will fit perfect. I ran them on my car and had no issues at all.
-Jomar-
1996 Mustang Cobra (jackstand world record holder)
2015 Silverado (daily beater)
slobra281 is offline
