4.6 build - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 05-19-2019, 05:33 PM Thread Starter
4.6 build
hi guys,
im at the limit of my stock engine. so im starting to plan a 4.6 build(already have a handfull of parts)
im looking more into compression ratios with boost. im thinking about going with a stroker setup(3.582 bore with 3.85 stroke) that should get me to about 11 to 1 compression with my trickflow heads.
my question is, 11 to 1 compression with 11-12# of boost intercooled with e85? thoughts?????
main parts i have
18cc dish pistons
4.6 block
trickflow 38cc heads
a bunch of ARP stuff
current motor has usual bolt ons
vortech @ 11-12psi
fuel system
a bunch more but dont need to explain
2002 gt...v2 strim, front mount cooler, Anderson power pipe, E85 tuned, victor jr. intake 60lb hr injectors, return style fuel system, longtubes, catless, 50/50s and strange 10 ways, Team Z UCA's and LCA
thebuilder is offline
post #2 of 8 Old 05-20-2019, 10:44 AM
I run 10.5:1 compression at 29 psi of boost with a Whipple 3.4l blower on e85...no issues here. It all comes down to tuning.
quikbluewagon is offline
post #3 of 8 Old 05-20-2019, 11:53 AM
KEVIN$'s Avatar
I agree with the above, it comes down to tuning. I don't know what issues you will have if any but for comparison I'm running 9.5:1 @ 32psi boost on E85 - twin turbo.
ks
Kevin Slaby
KEVIN$ is online now
post #4 of 8 Old 05-20-2019, 10:31 PM
CrucialProspect's Avatar
With ported pi heads (43cc chambers when I measured) I was running a lower compression with the 18cc heads, but bumped up with the 38 trick flows later on. I wouldn’t waste any money on a stroker kit if I had the choice, just my .02.
CrucialProspect is offline
post #5 of 8 Old 05-21-2019, 05:26 PM
Stroker is a waste of money. What are your goals? 11:1 on e85 is nothing with a good tune.
Sent from my COR-L29 using Tapatalk
ScottyDsntKnow is offline
post #6 of 8 Old 05-21-2019, 08:06 PM Thread Starter
Id like to be 700+rwhp was thinking the 11 to 1 could get me there quicker.
post #7 of 8 Old 05-21-2019, 10:11 PM
Is 11:1 possible with that deep a dish and cylinder head? I have the same setup with a .030 head gasket and I’m nowhere near that. Just a side thought, raising the compression can also minimize ptv clearance, which isn’t a terrible concern on the tfs heads, but it may be something to keep in mind if your lowering deck height, or however you plan on raising compression with that piston.
post #8 of 8 Old 05-23-2019, 09:00 PM
jamessr23's Avatar
Guys you should study the Andrew Lavender build for the 4.6
jamessr23 is offline
4.6 DOHC mild build (NA with the potential for boost) zackmd1 SVT & DOHC 10 11-27-2017 05:04 PM
4.6 Build input streeter69 GT & SOHC 6 10-01-2016 03:15 PM
LF: 4.6 3V engine build info yanrider GT & SOHC 0 08-15-2016 03:54 PM
4.6 Fox Build ltmyers407 Member Build-Up Projects 13 02-14-2012 08:56 PM
4.6 block build and differences questions ed302 GT & SOHC 8 10-14-2010 01:15 PM
