Subframe Connector Recommendations - Ford Mustang Forums : Corral.net Mustang Forum
 2Likes
  • 1 Post By AtomicCoupe
post #1 of 14 Old 05-05-2019, 11:30 PM Thread Starter
jamessr23's Avatar
Setting up a drag car (2003 GT). What subframes do you recommend? I'd prefer ones that have good clearance for getting the car in/out of the trailer.
jamessr23 is offline
post #2 of 14 Old 05-06-2019, 08:37 AM
If you want the standard bolt/weld in style, Maximum Motorsports subframes are great quality. If you are going to get more serious with a built drag car, I would suggest through the floor subframes like Wolfe Racecraft's setup.
Wolfe Race Craft - Detail
quikbluewagon is offline
post #3 of 14 Old 05-06-2019, 09:34 PM Thread Starter
jamessr23's Avatar
Roger I will check them out!
post #4 of 14 Old 05-07-2019, 08:03 AM
ZEN357's Avatar
ZEN357 is offline
post #5 of 14 Old 05-07-2019, 11:39 AM
AtomicCoupe's Avatar
Don’t buy subframe connectors. Just do it the right way and go through-floor connectors as stated. I also used Wolfe Craft.
jamessr23 likes this.
Stock block 306, V1 T-trim, AFM B-451 cam, TFS Twisted Wedge, Holley Systemax, A1000, Snow Meth, TKO 600, Team Z, Strange, MM, Lakewood and Moser helps me go forward fast.
AtomicCoupe is offline
post #6 of 14 Old 05-27-2019, 08:52 PM
I would say maximum motorsports, and if you do all of your work on the floor and like the notion of jacking rails, stifflers FIT system. My friend has those, they rock! I have the Kenny Brown extreme matrix kit double reinforced for a tq arm. The jacking rails are awesome! I find them worth every penny for me.
Snorky is offline
post #7 of 14 Old 05-27-2019, 09:05 PM
I’ve started to question how much sfc’s are really required.
There’s a buddy of ours who has a fairmont without subframe connectors. In fact, it doesn’t have any chassis mods except his k member for the ls. He cuts 1.2-1.3 60 times and 1/8 mile in the 5.4-5.5 range and he swears you don’t need subframe connectors. This isn’t his first fox body vehicle doing this with either.
I’ve personally rode in the car and it ####s and gets and there isn’t any noticeable flex. Not that I’m sure the chassis is the same but it can’t be that different.
1996 Mustang
347, 205 11R's, Box R Intake, Ported lower, custom comp cam, 42lb injectors, 255LPH, pro-m 80, 75mm Cheap-ass TB, 1 3/4 x 3in LT's, exhaust by me, A5 trans, 4.10
422WHP/456Ft/lb. Tuned using QH by Tony @ Tuners Inc.
96pushrod is online now
post #8 of 14 Old 05-28-2019, 12:31 AM
Maybe not, but you can sure as hell see a difference when you jack up an SFC car vs. one that isn't. I believe you'll bend up a unibody doing that, and at $200 or less, what's the issue?
FastDriver is offline
post #9 of 14 Old 05-28-2019, 08:09 AM
Through-floor....do it right.
post #10 of 14 Old 05-28-2019, 10:07 PM
I’m just saying; it’s tough to argue with wheel stands, 800whp and zero flex. I’ve never had issues jacking a unibody car.
Not like I’m saying sfc’s are bad, they’re not going to hurt anything.
1996 Mustang
post #11 of 14 Old 05-29-2019, 02:50 AM
I wouldn't call it an issue, but try opening and closing your doors.
post #12 of 14 Old 05-30-2019, 09:40 AM
KEVIN$'s Avatar
Originally Posted by 96pushrod View Post
Iíve started to question how much sfcís are really required.
Thereís a buddy of ours who has a fairmont without subframe connectors. In fact, it doesnít have any chassis mods except his k member for the ls. He cuts 1.2-1.3 60 times and 1/8 mile in the 5.4-5.5 range and he swears you donít need subframe connectors. This isnít his first fox body vehicle doing this with either.
Iíve personally rode in the car and it ####s and gets and there isnít any noticeable flex. Not that Iím sure the chassis is the same but it canít be that different.
So you are saying that he's running those times with No Cage or Roll Bar to stiffen the body, correct? I doubt you're saying this and if he has at least an 8pt cage then I doubt that there is a lot of flex but depending how the roll cage looks it's possible that he's not getting at least some flex even tho it's may not be noticeable.
ks
Kevin Slaby
KEVIN$ is online now
post #13 of 14 Old 05-31-2019, 09:13 PM
ks
This is what I’m saying. No roll bar, no cage, no subframe connectors nothing at all.
Car is a 81 (I believe, could be an 80) fairmont
He also makes 800whp on a single 6an feed line, using e85, so there’s a couple things he does which are unorthodox.
1996 Mustang
post #14 of 14 Old 06-02-2019, 07:37 PM
KEVIN$'s Avatar
This is what Iím saying. No roll bar, no cage, no subframe connectors nothing at all.
He also makes 800whp on a single 6an feed line, using e85, so thereís a couple things he does which are unorthodox.
Well, if there is no stiffening bars then I can assure you that the body/frame IS 1000000% flexing. Being a Fairmont adds extra panel stiffening but obviously it's not an issue that he cares about which is kewl by me.
ks
Kevin Slaby
Question for Body / Frame Experts Regarding Body Flex and Subframe Connector Installation BrettNorton The Body Shop 1 03-15-2015 07:28 PM
Question for Body / Frame Experts on Subframe Connectors Installation BrettNorton 94/95 Tech 6 03-06-2015 10:33 PM
Did Maier Racing change the design of their subframe connectors? Cylindrical design? STREETFIGHTER50 General Mustang Tech 3 11-12-2008 01:14 AM
Subframe Tech article, Drive on Hoist vs Post NXGHOST General Mustang Tech 26 08-29-2003 01:37 PM
