2013 gt500 broke already - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 27 Old 08-26-2012, 02:19 PM Thread Starter
So I'm driving to a car show in my 13 with about 1700 miles on it and I get a engine light about a mile down the road. I look at my gauges and notice my air temp says zero. I shut it down restart it and it looks normal again. I continued on my way and the car dropped dead No power and stalling. I get it home and scan it and get a mas air and iac code. wtf Ford. Dam thing was fine the night before. Let's just say I'm pissed. I buy a brand new car to avoid things like this.
TFS track heet intake TFS Track heet heads Stock block Procharger P1-SC @ 11psi Aeromotive AFPR Snow methanol inj 60 Psi SD injectors Pro-M univer mass air 75mm throttle body Fluidyne rad T5 with bassani O/R x pipe bbk short headers
PMS With SCT CHIP for fan and injector settings
94gt_vert_procharged is offline
post #2 of 27 Old 08-26-2012, 05:13 PM
Trader Feedback: (71)
That sucks. Let us know what Ford does to fix it.
1986 Mustang GT Coyote swap project car
1991 Mustang GT LS1 HCI, C4, 3.90s, [email protected]
91foxbodygt is offline
post #3 of 27 Old 08-26-2012, 06:07 PM
CobramanPhil's Avatar
Kind of reminds me of when I picked up a 5k mile viper and it spun a bearing after 1200 miles of driving. Seriously though it may be something very simple like some debris on the MAF wire. In a good way the car is telling you to get it checked out so you don't do damage to your motor...keep us posted.
CobramanPhil is offline
post #4 of 27 Old 09-06-2012, 06:26 PM
Do you still have the stock air filter set up on the car?
96 GT Vert, 76mm turbonetics, built 4r70w w/brake, UCC Converter, 60lb inj., ba2400, 10.96 @ 124 w/19psi, stock heads, stock intake, stock exhaust manifolds, stock tb. Tuned with a Tweecer
http://www.lubedealer.com/newenglandperformanceproducts/
turbo96 is offline
post #5 of 27 Old 09-06-2012, 07:01 PM
Sensors go bad sometimes. They'll swap it out and have you running perfect in no time. Its not like it threw a rod out of the block at idle or something. New cars break too they're just fixed under warranty for free.
Misspelled while on the crapper via my Droid Razr
'09 GT500 Vert - Vapor Silver - Stripe Delete - Red/Black interior (1 of 4)
GT500KR springs and shocks, GT500KR axle back
mavisky is offline
post #6 of 27 Old 09-07-2012, 01:10 PM
jpicc's Avatar
I agree....post title made it seem like something major had happen. It's a sensor they go bad, I'm sure Ford will fix.
2004 Competition Orange GT.
Twin 57's
Custom turbo kit....built by myself
jpicc is offline
post #7 of 27 Old 09-08-2012, 01:30 AM
I'd be raising hell if I were the OP. 1700 miles in a 60k car and something happened already.
2005 GTO 402ci twin turbo
2006 GT. Cams:gears: corsa
2012 dodge ram 3500. Stock
Cabikejumper is offline
post #8 of 27 Old 09-08-2012, 11:28 AM
Tob
Is this car 100% stock? If so, nothing to worry about - Ford will fix it. Inconvenience? Absolutely.
Tob is offline
post #9 of 27 Old 09-08-2012, 12:56 PM
frankstang's Avatar
Trader Feedback: (115)
Mechanical/electrical parts fail, it's a fact. I'm sure Ford will have you up and running as soon as you give them the opportunity to fix it.
We're assuming the car is in stock form.
frankstang is offline
post #10 of 27 Old 09-08-2012, 07:59 PM
NJBlackGT's Avatar
I'm with the OP. I would be pissed too. Whether you pay a little or a lot for a new car, you're putting money towards something you want to enjoy, not watch it being worked on in the service department.
Ford will fix it major or minor, but it is still an inconvenience.
OP - let us all know what it turns out to be. I'm real curious as I want to hear more real life stories about the car. By the way, congrats on the car. You bought one sick machine!
2003 GT (5 speed) - TFS heads & cams, full exhaust, 3.73 gears, CAI, t-body, plenum, dyno tune... just to name a few
NJBlackGT is offline
post #11 of 27 Old 09-09-2012, 08:24 PM
bod89lx's Avatar
Trader Feedback: (88)
So has Ford fixed the car yet or is it still at the dealership?
2013 GT500 SGM \Black Stripe.
2003 Cobra Redfire
1986 GT 408W C4 T-Top Factory Paint
2013 Ram 2500
bod89lx is offline
post #12 of 27 Old 09-13-2012, 04:32 PM
RazorbackMustang's Avatar
Is there an IAC display on the 2013? If not....how do you know it was reading zero? If there is, that sounds like it's either unplugged or just a bad sensor.
Lucas
2011 Mustang GT
2013 Fusion Titanium
RazorbackMustang is offline
post #13 of 27 Old 09-13-2012, 05:59 PM
So what did it turn out to be?
post #14 of 27 Old 11-07-2012, 01:47 AM Thread Starter
Sorry for not getting back to you guys. It was the maf meter. I had a bad experience getting the car towed and serviced. Tow guy scraped the hell out of the front and didnt care. ford put the new meter on drove it 30 miles and didn't even clear the codes or wash it after they drove it in the mud. for a $113 part i wish i did it myself. As of now the car has a lund tune jlt intake twin 65mm throttle body and i just got the borla atak mufflers not installed yet. Problems i don't want to take it back for as of now, grinding on take off in 1st gear, clutch pedal sticks half way to the floor at a 6800rpm shift. Other then that i love the car after the tune and tb
post #15 of 27 Old 11-12-2012, 01:31 PM
If you have clutch issues take it back to the dealership. Better to document now as compared to having a catastrophic failure down the road and then telling the dealership it is broke. If you let them know now they will more likely replace it under warranty when it was first noticed to be having issues as compared to later when they will say you abused it even after noticing there were issues.
post #16 of 27 Old 01-27-2013, 08:05 AM
foureyed's Avatar
More than likely a piece of dirt got on the MAF wire. The tech will just replace it since its still under warranty. The only issues we have been seeing on the Shelby's so far is the clutch and second gear problems. The clutch was updated in 2010 so that has been rectified. Second gear synchro is now carbon fiber. However people who beat the hell out of these still manage to strip out second gear. Other than that they are pretty solid cars.
Carbon fiber blocking ring
foureyed is offline
post #17 of 27 Old 01-28-2013, 01:03 AM
Shakerhood's Avatar
Back in 2002 when I picked up new GT the check engine light came on while driving home from the Dealership, I think it had about 54 Miles on it! I had to take it back and get a POS loaner car, some sensors had failed for some reason, needless to say I was pissed.
Shakerhood is offline
post #18 of 27 Old 01-28-2013, 01:32 AM
im a ford tech..and I can tell you its very common for flys and other debris to get sucked up in MAF sensor and cause it to do exactly what you said usually just needs cleaned which is a perfectly acceptable method but they tried doing even better thing it appears and replaced whole sensor under warranty. If you have problems bring it in the techs dont care its money in there pockets and its warranty work so you dont pay and any ford tech like myself would be honored to fix a gt500..
coupefox90 is offline
post #19 of 27 Old 01-28-2013, 08:59 AM
Originally Posted by coupefox90 View Post
im a ford tech..and I can tell you its very common for flys and other debris to get sucked up in MAF sensor and cause it to do exactly what you said usually just needs cleaned which is a perfectly...
And how are the flies and debris getting past the filter?
na svt is offline
post #20 of 27 Old 01-28-2013, 11:14 PM
na svt usually when people dont get them properly installed, and sometimes have found them even when filter is installed just fine so good question.
post #21 of 27 Old 01-29-2013, 07:02 PM
TomR's Avatar
Following a Corvette too close might infest a GT500 intake with worms and flies.
TomR is offline
post #22 of 27 Old 01-30-2013, 07:37 PM
i agree with everything you said except warranty work is not always accepted and encouraged, flat rate times are sometimes just rediculous and can cause a rush. nice to see they did replace the MAF.
jbodell11 is offline
post #23 of 27 Old 05-31-2013, 12:52 PM
Trader Feedback: (22)
that must have been one hell of a fly for all of this to happen
03 Mustang GT
Turbo 2v
LS1KILR is offline
post #24 of 27 Old 06-13-2013, 10:10 PM
slowhatch's Avatar
Any and all cars break even the most expensive ones. No reason to get pissed, they took care of it even though it had some modifications(if im reading your post correctly). I am a tech and can say that I have repaired plenty of new and low mileage cars. I have replaced body harnesses, engines, transmissions and plenty of other major components that make a mass air meter look like chump change. Hopefully you dont have any other issues. Enjoy the car. Dave.
347, AFR 185, FTI cam, Systemax, shorties, 2.5'' exhaust, stock airbox, 70mm tb, 75mm MAF, 24lb
387rwhp, 397rwtq, [email protected] first passes, more track times soon
slowhatch is offline
post #25 of 27 Old 07-14-2013, 12:37 AM
i'd be pist too
when you buy new you expect new as in no issues for a while
Decipha @ EFIDynoTuning
www.efidynotuning.com
Decipha is offline
post #26 of 27 Old 10-12-2014, 12:44 AM
A2V2NV's Avatar
So....what about the tow truck driver? You let him go with scratching it up?
2001 GT
418 RWHP/376RWTQ
John 3.13
A2V2NV is offline
post #27 of 27 Old 10-13-2014, 12:49 PM
Rfreeman37's Avatar
I guess I would be ready to fix it too. Its an amazing car to drive.
Interesting how flies would get sucked into and past a paper filter but nothing surprises me. As far as following Vettes too close I would think the GT500 should be a good match for a Vette. If not beat it. Unless you are referring to the ZR1 which wow better then a 100k car it should win.......if it can.
Christ First.
Romans 12:2
Rfreeman37 is offline
2011 GT500 to 2013 GT500 front grille and chin spoiler install.... Christopher Ihara GT-500 (2007-Present) 11 11-05-2012 01:24 AM
Check out this link - 2013 Shelby GT500 on dyno, shows more power Cobra Jet NJ Lounge 3 05-24-2012 01:03 PM
2013 Ford Shelby GT500 is Most Powerful Production V8 in the World! panther007 GT-500 (2007-Present) 6 04-02-2012 06:17 PM
2013 Shelby GT500 to Top Camaro ZL1 With 600-HP AutoGuide.com News 0 03-16-2011 10:38 AM
