2007-2009 GT500 differences?? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 05-27-2012, 08:48 PM Thread Starter
Trader Feedback: (43)
I've been looking at GT500's for sale and I like the 07-09 models. I just can't get into the bodystyle of the 2010+ versions. I don't know much about the options or changes that were made from 07-09. Can someone tell me what changes took place form 07-09 and if one year is more desirable than the other? What were the factory options? Were there any engine or powertrain changes made? Were they all 500 horsepower? Were there any enigne problems with the 07-09's? Thnaks for any advice.
Just an old carpenter with a 94 Cobra and a Son with a nasty 85GT! I'm Show and he's Go!!
XSPOWER is offline
post #2 of 7 Old 07-06-2013, 12:31 PM
It's been over a month so I don't know if you will see this response but here goes. I just purchased a 2009 after shopping for a very long time. The 2007-2009 cars are supposed to have 500 hp at the crank. For the 2007 ones that was not the case as they came in at around 490 or so when tested after hitting the streets. Ford went back and changed the computer tune midway thru the 2008 models to actually get the 500 hp at the crank. So the later 2008's and all 2009's should be as advertised for hp.
Now the BIG issue with these cars, the clutch. Ford made a faulty clutch and put out 3 or 4 different technical bulletins about it but never bumped it to a recall because it's not a safety issue. Basically the clutch may give out at any time without any prior warning. You may notice a lot of people mentioning how stiff the clutch is on the 07-09's, that's part of the problem. Ford fixed this issue by completely changing the clutch in 2010 and the final tech bulletin advised to put the 2010 clutch in the 07-09's to fix the problem. When I bought my 09 I made sure it already had the clutch upgrade because it's like 5k to do after the fact.
Other than that, no problems or issues. These cars are awesome and put down some sick power! I plan on keeping mine for a very long time.
arlander is offline
post #3 of 7 Old 08-26-2013, 10:45 PM
Thats good to know Arlander, thanks.
Saleen714 is offline
post #4 of 7 Old 11-16-2013, 08:01 PM
DRAGPAK's Avatar
The 2009 has a different exhaust mid pipe ,07 had a different har balancer .
86 svo t3/t4 50 trim stage 3 turbin 63ar front mount sparco , 450 lift 280 dur cam , adj cam sprocket ,atr header,alum driveshaft,5 way tokico,98 cobra brakes
2009 gt 500 jtm vpm steeda sus .84 stock svo
DRAGPAK is offline
post #5 of 7 Old 12-27-2013, 08:35 AM
Banned
"2008 and 2009 have the HID headlights and ambient lighting. 2007 and beginning half of 2008 had the old transmissions that would warp. Ford has taken care of that for the most part and is replacing them with 2010 unites under warranty. Other than that there is no other difference. If it helps each HID headlight is a little under 1000 dollars from the dealer so it is an expensive upgrade if you consider it for a 2007."
post #6 of 7 Old 01-22-2014, 03:17 PM
Please explain how a transmission can warp!
bullstang is offline
post #7 of 7 Old 03-02-2014, 07:06 PM
Modular2v's Avatar
It's the flywheel that warps
03 2v 5spd: MMR 4.75 stroker, 76mm kit, CMS stage 2 Turbo cams 3.73s, cold air, BBK throttle plenum,, sct software, upper and lower control arms. Spec stage 3 clutch. Lethal Return fuel system w/ Twin 255s [email protected] with a 2.067 60'
Modular2v is offline
For Sale 2007 Shelby Mustang GT500 lower intake Sapphire95 Modular Engine Parts 5 10-10-2013 08:43 PM
For Sale 2007 Twin Turbo Shelby GT500 JZeilinga Mustangs For Sale/Wanted 2005-Present 1 07-20-2011 02:32 PM
For Sale Brand New Jet Performance Ford programmer #15043 j.largent87 Electronics and Entertainment 3 06-27-2011 10:59 PM
2009 mustang gt with 2007 gt500 t56? fast sleeper S-197 Mustang (2005-2010) 5 01-31-2011 12:50 AM
