2013 Shelby GT500 Predictions (bolt ons) - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 23 Old 02-13-2012, 02:56 PM Thread Starter
CobramanPhil's Avatar
Not that I would mess with a new car (and its warranty...shssh..don't tell the wife), but what are some predictions for a stock 2013 GT500 with simple bolt-ons and a tune (i.e. pulley, chip, tuning, maybe meth kit)? Sorry for my lack of knowledge....not really familiar with what the Shelby setup (ask me anything about the 94-95 cars though
Looks like my garage queen is going to end up in another person's garage if this new car comes in for me
2013 Shelby GT500 PP/TP
2003 Viper (blew up)
2002 Viper (SOLD)
1995 Cobra SOLD
CobramanPhil is offline
post #2 of 23 Old 02-13-2012, 03:24 PM
filthy1's Avatar
I wouldn't be surprised to see 650 to the tires with a pulley, tune and exhaust.
1995 GT Vert - Ported Trick flow heads, ported track heat intake, cam, longtubes, etc. It's slow.
2002 GT Coupe - Sold
XBOX 360 - SCUZEME32
filthy1 is offline
post #3 of 23 Old 02-14-2012, 12:43 PM
NJBlackGT's Avatar
So we're thinking a 10 second car with bolt-ons? And an 11-second car right off the showroom floor?
2003 GT (5 speed) - TFS heads & cams, full exhaust, 3.73 gears, CAI, t-body, plenum, dyno tune... just to name a few
NJBlackGT is offline
post #4 of 23 Old 02-14-2012, 01:39 PM
Smile
Correct !!!!!!!!!!!
Nick1 is offline
post #5 of 23 Old 02-14-2012, 02:06 PM
filthy1's Avatar
I'd say so. I think its going to come in around 550 to the tires in stock trim. 550 to the tires in a car that weighs 3800-3900 lbs should be good for 11's all day if it can hook.
filthy1 is offline
post #6 of 23 Old 02-14-2012, 05:38 PM
I'm thinking very close to a 10 second car with just drag tires. 550 rwhp is plenty to run 10's @3800 lbs with a 1.6 60ft.
tistan is offline
post #7 of 23 Old 02-15-2012, 12:41 PM Thread Starter
Thanks for all the replies.
I guess just as a comparison what are the 2012s running with (Hp/trapspeed mostly) with bolt-on (i.e. pulley tune)? The only thing I am concerned with is breakage simply from the weight of the car. Street tires can be that "switch" which can offset it simply by losing traction. With slicks or even drag radials I would be worried with the rear end with that amount of power
The wife suggested I get the 2012 last night. She said considering how great the 2013s will be...just think of the discounts the 2012s will be at..hmmm,,,another option I guess..
2002 Viper (SOLD)
1995 Cobra SOLD
post #8 of 23 Old 02-16-2012, 06:59 AM
sounds like you have a keeper.
BLK2012GT is offline
post #9 of 23 Old 02-16-2012, 08:24 AM
filthy1's Avatar
I'd hold out for the 2013...
filthy1 is offline
post #10 of 23 Old 02-17-2012, 07:37 AM
NJBlackGT's Avatar
I would without a doubt hold off for a 2013. I don't think the savings will be significant enough to overcome the "what if" feeling you'll have for years to come if you get a 2012.
post #11 of 23 Old 02-17-2012, 10:29 AM
Tryin to hook it up is the BIG thing. So does Ford make an automatic that could handle 700hp ??
Dan
88 Mazda RX7 Buick V6 Turbo powered
87 Buick GN.. Daughter's beater [email protected] street trim
Ton of 86/87 Buick Turbo parts for sale !! Time to move on
Blue 66 is offline
post #12 of 23 Old 02-17-2012, 10:11 PM
Based off what I know. They have added .4L, a bigger blower, more boost, and more compression. I know most 15psi TVS GT500's with the 8.6:1 and 5.4L motor are making well over 600whp. SO I think 550whp is a MASSIVE underrating. That said, Ford may have this motor MASSIVLY detuned and I would not be surprise if we see 600-625whp with noting but a custom tune. I just cant see a 5.8L tvs charged, higher comp motor running 5+psi over the last gen motor only making 75ish more whp. You can get 75 extra hp on the current stock blower/motor @15-16psi and a tune soooo.
What im curious about is if the aftermarket will be able to really add more boost while keeping the car 91 octane friendly. 15psi is a lot stock. I guess you might be able to add 2-3psi maybe. I think it will be nasty with an E85 conversion and full boltons.
Truebluedevil02 is offline
post #13 of 23 Old 02-20-2012, 08:53 PM
The supercharger pulley on the '13 barely clears the snout O.D. so there won't be any real estate to go smaller.
One of the first mods to do will be to replace the throttle body...it appears to be the same bore size as the earlier models had.
DrTriton is offline
post #14 of 23 Old 02-21-2012, 07:37 PM
Meangrn92GT's Avatar
Trader Feedback: (62)
Hot Rod mag said they watched the engine dyno at 67x hp on a engine dyno, so you can make guesses based off that as to what it'll throw down at the tires.
-Dave
1992 Mustang GT
Meangrn92GT is offline
post #15 of 23 Old 02-21-2012, 08:35 PM
That would go right in line with my guesses, I bet well see them in the 590-600whp range bone stock.
post #16 of 23 Old 02-21-2012, 09:36 PM
I don't have the issue here at the house so I can't confirm or not if the accessories were on the engine during that pull, so take that number with a grain!
-Dave
1992 Mustang GT
post #17 of 23 Old 03-02-2012, 08:21 AM
TURBOX2's Avatar
The 2013 will likely be near 60k, a 2012 can be found for ~45k, so it depends on your budget as much as anything. 60k is a whole different world of car purchase than 45k.... I could swing a 2012 if I really found it that important to spend that much on a car, but 60? Might just as well be 90, its not even in the conversation..... Cobramanphil, if you've got the budget for it the 2013 should be an astounding car, if its really pushing it then a 2012 with some bolt-ons is pretty awesome too.
Dan Simons
'11 5.0, M6, 400a, 3.73s, HIDs, 19" GT500 wheels, GT500 axle-back, Airaid cai, Steeda ultralite springs, Steeda shifter, more to come...
'01 Roush F150 Screw, 5.4 3v swap, longtubes, ported heads, XCal2, '03 Cobra maf, 30lb inj, moves pretty good for a whale.....
TURBOX2 is offline
post #18 of 23 Old 03-05-2012, 04:25 PM Thread Starter
LOL..to be honest I have been guilty of buying more expensive cars for the wife(ask my wife..who thinks buying status cars is all the rage and she should replace them every two years). This time (and I know I have ranted up and down in the past that I would never get rid of my 95 cobra) the car is going to have to be pretty fast out of the box since I have no immediate plans to mod it (unless I have to..thinking the times this car will run will require a cage).
2002 Viper (SOLD)
1995 Cobra SOLD
post #19 of 23 Old 03-05-2012, 08:35 PM
CorteXracing's Avatar
Besides the motor there will also be the issue of lowering the car so it does not have the "classic" S197 mustang 4x4 stance. Since it will be offered with an active suspension option it will not be as simple as bolting on a nice coil over package.
CorteXracing is offline
post #20 of 23 Old 03-07-2012, 01:06 PM Thread Starter
I agree, but from all the pictures of the new model, it appears pretty low already. Plus..I am tired of scraping my driveway with the current car...lol
2002 Viper (SOLD)
1995 Cobra SOLD
post #21 of 23 Old 04-22-2012, 11:36 AM
Thunder5.0's Avatar
The new GT 500 wears the badge:
Thunder5.0 is offline
post #22 of 23 Old 05-21-2012, 09:18 AM
filthy1's Avatar
Dynojet Run 609 RWHP - SVTPerformance
According to this thread 609 is the lowest number one of the members of SVT Per. has seen with 624 being the highest.
Sick...
filthy1 is offline
post #23 of 23 Old 05-22-2012, 02:20 PM
Trader Feedback: (40)
Personally what i would do is:
Wait...let somebody else have the honors of paying full price for one of these bad boys. 60k is alot, im sure many people will spread themselves out too thin to be able afford the car for a long period of time. When that person sells it with 10k miles for $50ish for a quick sale just so he can keep afloat, thats when you move in and come to the rescue. Then you have successfully got the car you wanted and paid substantially less than initially planned. It happens all the time with new cars, and with all the hype, this car will be no different. Only drawback is you might not be the first on the forum to have one, who cares haha.
Anywho, thats my .02.
Unless youve got the dough then get it new. They are going to be sick cars.
notchthis is offline
For Sale Polished aluminum strut bar is custom made for 2007-2009 Shelby GT500 SuperSnake Colorado Cobras S197 and Coyote Parts 11 07-18-2014 12:40 AM
2013 Ford Shelby GT500 is Most Powerful Production V8 in the World! panther007 GT-500 (2007-Present) 6 04-02-2012 06:17 PM
For Sale MMP's 1000hp Shelby GT500........look within for all details!!!! Muscle Motors Performance Mustangs For Sale/Wanted 2005-Present 6 08-23-2011 11:01 AM
2013 Shelby GT500 to Top Camaro ZL1 With 600-HP AutoGuide.com News 0 03-16-2011 10:38 AM
