2011 Shift problems - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 25 Old 09-29-2010, 04:14 PM Thread Starter
Angry 2011 Shift problems
I searched and found nothing, but I have a 2011 and the 1-2 shift is not gonna happen above 4k rpms. Am I the only one with this problem?
High_Voltage is offline
post #2 of 25 Old 09-29-2010, 05:45 PM
clean93's Avatar
I believe Ford released a TSB on this a few days ago. id take it right back to the dealership. its an issue on the 2010's too
Aaron
1993 Mustang GT built and tuned by JPC Racing
clean93 is offline
post #3 of 25 Old 09-29-2010, 06:02 PM Thread Starter
SWEET!!
post #4 of 25 Old 09-29-2010, 06:15 PM Thread Starter
I checked and the TSB issued is for the GT's MT82. Not the 6060 The new TSB describes the clutch pedal staying on the floor.
post #5 of 25 Old 09-30-2010, 12:33 AM
clean93's Avatar
ok well i guess theyll give a TSB for GT500's in the future. they take there time. its a common complaint from last year of pedals getting stuck. now the new one is higher rpm shift issues. Id take your shelby to Ford anyways they should take care of you.
Aaron
clean93 is offline
post #6 of 25 Old 10-01-2010, 04:02 PM
RazorbackMustang's Avatar
My 2010 GT500 had this problem. It was a real PITA. I got waxed by a freaking Charger R/T once because of it. Supposedly they have a fix they can do if you can find a dealer that will mess with it and is knowledgable. It's definitely a well known problem though and very annoying. Many owners have said if you make positively sure the clutch is pushed to the floor, it helps.
Lucas
2011 Mustang GT
2013 Fusion Titanium
RazorbackMustang is offline
post #7 of 25 Old 10-02-2010, 12:57 AM
clean93's Avatar
i hate charger R/T's
Aaron
clean93 is offline
post #8 of 25 Old 10-11-2010, 10:13 AM
ekafrawy's Avatar
I am having the same problem with my 2011 GT500. Last night it was happening with shifts from 1st to 2nd under 2500 rpm. I'm going to call my dealer to see if there is TSB out for this issue.
Check me out on Youtube, and Instagram: EKAutoTech
2011 Mustang Shelby GT500, SVT PP
94 GT, Vortech V2 SQ, Cobra intake, Edlebrock 65mm TB, Pro-M 75mm mass air, 30# inj, Flowmasters, Hooker headers, BBk H-pipe, Walbro 255, 3.55 gears,kyb shocks/struts, 17x9 svt Chrome Cobra R's, 275/50/17 Nittos
ekafrawy is offline
post #9 of 25 Old 10-11-2010, 02:47 PM
Trader Feedback: (30)
Ford is working on a TSB. There are a couple guys on SVTP that have the same problem as well. I work with Fords Media/Press vehicle fleet management and I brought the problem to their attention with our '11 GT500s. The Ford PAVE team also knew about the issues, and I was able to confirm them with a couple of 1-2 WOT blasts. Hopefully the TSB will be for a Carbon Fiber 2nd gear syncro, and not just a trans replacement.
It is a Tremec TR6060 problem. Dodge had the same issues as well.
-'90 Mustang LX Coupe 5.0 SSP. 83 DSO US Gov't Issue. H/C/I Track toy
93Krwy is offline
post #10 of 25 Old 10-11-2010, 04:45 PM
As do the GM vehicles with this transmission.
Lucas
2011 Mustang GT
post #11 of 25 Old 10-18-2010, 07:24 AM
Founder corral.net
Christopher Ihara's Avatar
I am having the same problem with my 2011 GT500 as well. It seems to be worst when the trans is cold. Once things warm up it is improved. It will do it an any speed and any RPM on the 1-2 shift.
Ford told the Tech at the dealership that I should be sure to move the seat up 1". They also said to make sure I had the clutch pressed down all the way.
It seems they are in denial that they have a problem.
"Those who would give up essential Liberty, to purchase a little temporary Safety, deserve neither Liberty nor Safety." - Benjamin Franklin
Christopher Ihara is offline
post #12 of 25 Old 10-19-2010, 12:46 AM
A lot of people were able to "drive around" the problem by making sure the pedal was depressed all the way. In truth, I don't think this is a FORD problem, but rather a Tremec problem.
I definitely noticed it more when the transmission was cold, but even at full operating temp it still did it on any kind of quick shift.
Others have mentioned that a shifter swap fixes it as well. Check this thread for a lot of info on it: http://www.teamshelby.com/forums/ind...072-1-2-shift/
Lucas
2011 Mustang GT
post #13 of 25 Old 10-19-2010, 11:30 PM
Founder corral.net
Well I made sure to mention the problem in my review of the 2011 GT500. Hopefully this will get someone's attention.
post #14 of 25 Old 11-08-2010, 08:03 AM
Founder corral.net
I will be checking today, but I understand that there is an updated transmission. Hopefully this will fix the problem. I will let everyone know when I find out.
post #15 of 25 Old 11-08-2010, 06:57 PM
Anyone tired different motor mounts or strapping one side of the engine. it's a common problem with lots of power and remote shifters.
10secgoal is offline
post #16 of 25 Old 11-09-2010, 05:40 AM
Administrator
Greg@GLD's Avatar
I have about 165 more HP than Chris does and still run the stock shifter. It's hit-or-miss as to who has issues or not...
In Loving Memory of Dave Bandt
11/19/69-3/23/08
1990 Mustang GT Ragtop
1992 Mustang GT Vortech Supercharged
1994 Mustang Cobra Vortech Supercharged
1995 Mustang GTS
1995 Mustang GT Ragtop
1995 Lightning 427 Windsor Procharger F2
2019 F150 3.5 Eco
post #17 of 25 Old 11-09-2010, 05:40 PM
wbt
Corral Member
Wifes 2010 GT500 has been rock solid as well.
wbt is offline
post #18 of 25 Old 02-03-2011, 12:48 PM
ekafrawy's Avatar
Anyone hear any recent news on this issue? I have about 1400 miles on mine, and I haven't noticed the 1-2 shift grind in a while.
ekafrawy is offline
post #19 of 25 Old 04-18-2011, 06:25 PM
Originally Posted by RazorbackMustang View Post
My 2010 GT500 had this problem. It was a real PITA. I got waxed by a freaking Charger R/T once because of it. .
I bet that guy is still bragging about it too.
Nicholaskl is offline
post #20 of 25 Old 04-21-2011, 11:54 AM
Founder corral.net
Supposedly the fix for this problem is to use a different kind of transmission oil. I will be taking the car in next week to see if this alleviates the problem.
post #21 of 25 Old 04-27-2011, 10:49 PM
Oh no doubt. I've seen him a few times since. We had another go at it but this time in the 5.0, let's just say it wasn't a repeat of the first meeting.
Lucas
2011 Mustang GT
post #22 of 25 Old 06-01-2011, 06:28 PM
Founder corral.net
OK, the dealer changed the fluid. Prior to that though I had not noticed the grinding problem once the weather warmed up. It was already temperature related, I just didn't know what temperature was required to make it happen.
It happened once more when the temperature was in the low 50-degree range even after the fluid change. So as far as I can tell the fluid change didn't solve the problem.
I may just have to trade the thing in on a 2013.
post #23 of 25 Old 08-08-2011, 04:39 PM
ekafrawy's Avatar
Saw this article today. Is this the same issue we are seeing with out GT500s?
NHTSA Investigating Complaints About Chinese-Made Ford Mustang Transmissions - FoxNews.com
ekafrawy is offline
post #24 of 25 Old 08-23-2011, 08:13 PM
bod89lx's Avatar
Trader Feedback: (88)
Nope that is on the MT-82 Trans in the GT's not the 6060 in the GT500, BTW my 2012 has the problem jst waiting on a part that is on back order to take it in for a possible fix. I will also be installing a MGW shifter at that time .
2013 GT500 SGM \Black Stripe.
2003 Cobra Redfire
1986 GT 408W C4 T-Top Factory Paint
2013 Ram 2500
bod89lx is offline
post #25 of 25 Old 08-27-2011, 04:13 AM
I'm just going to pull mine out and apart and replace it with better lined blockers
problems with AOD after shift kit 1991_5.0_convertible General Mustang Tech 32 11-01-2014 03:57 PM
Problems on the 1..2 shift at the track! GearSlamminStang General Mustang Tech 3 05-30-2003 12:56 PM
high rpm shift problems with TKO, used to shift fine. Dave Hart SVT & DOHC 3 04-22-2003 07:50 PM
Tremec shift problems Hatecrow General Mustang Tech 0 10-13-2002 08:16 PM
shift light problems white94 Electrical & Wiring 3 03-21-2002 11:57 PM
