First, while Im doing my electric fan I want to make the top of my radiator look better.
I started sanding it to paint it with a hightemp color, and saw the pertyness underneath. If I just sand it and leave it as is, will it rust?
If I do paint it, do I need to prime it?
The outter part of the radiator(where the cap is, etc) looks to be brass, I will paint this area, do I need a primer? or a special type of primer?
Second question:
My taurus fan has a gap when its flat against the radiator. Should I be concerned about seaing it? If so, I was thinking about some window foam or something from home depot? Any problems you guys can seat with the heat from the radiator melting that stuff?
Second question:
