1989 5.0 idle speed - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 10 Old 09-09-2019, 09:39 AM Thread Starter
HoosierBuddy's Avatar
1989 5.0 idle speed
Guys,
Working on a 1989 5.0. I set the idle to 750 with the IAC disconnected (engine hot). Then I disconnected the battery for several minutes to clear out the memory. Hooked everything back up and got the idle right at 750 where I want it.
However, after test driving for 10 or 15 minutes, the idle is back at 1000. I can disconnect the IAC and it drops.
Seems like the ECU is using the IAC to speed up the idle.
A guy at work suggested cleaning the IAC. I have not tried that yet as it seems to be working...i.e no surging, just a high idle speed. Question though...I note that you can blow through the valve when it is off the car. Does that indicate it has a problem? Shouldn't it be closed with no power to it so it wouldn't pass low pressure air?
Other than this, the car is running great.
Phil
HoosierBuddy is offline
post #2 of 10 Old 09-09-2019, 11:14 AM
indy2000's Avatar
ECM controls idle
There used to be a ‘do not adjust label’ under the hood to inform people of this
If this is a totally stock engine, you can try the idle reset procedure designed for factory engines, ie stock TB and MAF....
It is normal for the valve NOT to be totally sealed
indy2000 is offline
post #3 of 10 Old 09-09-2019, 11:31 AM Thread Starter
Originally Posted by indy2000 View Post
ECM controls idle
Good info. So is the idle reset procedure different than what I described above...i.e. setting to 750 with IAC disconnected and power cycling the ECU?
Phil
post #4 of 10 Old 09-09-2019, 03:47 PM
indy2000's Avatar
its not really a idle reset, its a stop reset
in stock form, you get the engine nice and hot
disconnect the SPOUT, idle is actually set by timing by the ecm the IAC is for transitions and loads, then disconnect the IAC
get the engine to idle as low as posssible, 500-550rpm by backing the adjusting the stop
then erase the KAM, disconnect the battery step on the brake pedal
restart, goose the engine a few times
then wait for about 100 start cycles at different conditions, idle will learn
this may work or not, its only chance is with a totally stock engine.
indy2000 is offline
post #5 of 10 Old 09-10-2019, 08:30 AM Thread Starter
It's near stock...but not totally.
Very interesting info on timing setting the idle.
So...this 1989 has 160,000 miles on it. The engine was rebuilt about 130...but I just reused the stock distributor. Any chance the distributor is more the issue here?
Phil
post #6 of 10 Old 09-10-2019, 09:48 AM
indy2000's Avatar
if it runs, doubtful the dist is an issue
what is not stock??
indy2000 is offline
post #7 of 10 Old 09-10-2019, 02:48 PM Thread Starter
GT40P Heads. E-Cam.
Running a 1994 MAF. I did have a larger TB installed, but went back to stock to help this idle issue. It did help, as the old (non-stock) TB had an air leak past the throttle body blade.
Phil
post #8 of 10 Old 09-10-2019, 04:33 PM
indy2000's Avatar
YOU CAN TRY the reset procedure
If it doesn’t work, you will need a ecm recalibration, to account for the different airflow at idle
I am not sure, what you mean by air leaking past the blade, as they have to
indy2000 is offline
post #9 of 10 Old 09-11-2019, 06:38 PM
THELAW1's Avatar
Idle reset ...https://www.corral.net/index.php/tec...ment-and-reset
89 Reggatta blue,Trickflow Intake,
1in spacer.65mmTB,GT-40 aluminum heads(X303),3000 Dynamic Converter, Motorcraft plugs 32c's ,E-cam,24lbs Injectors,Pro-M 76mm Mass air , AOD,shift-kit, modified valve body, 410 gear, Eaton
THELAW1 is offline
post #10 of 10 Old 09-11-2019, 08:09 PM
indy2000's Avatar
that is completely useless and will lead to other drivability issues
indy2000 is offline
