Question for those that have rebuilt their T5's - Ford Mustang Forums : Corral.net Mustang Forum
 1Likes
  • 1 Post By Mustang5L5
post #1 of 3 Old 06-19-2019, 09:57 AM Thread Starter
fox88's Avatar
Mine, was rebuilt just before I bought the car. Has prob. less than 2k miles on it. Bearings, races, synchro's all look new. How much, if any, can I reuse and or should I replace?
I've got a 2.95 gear set, steel input retainer, billet cluster support, billet 3/4 keys & bronze fork pads. Would it be that big a deal since everything else looks so good just to swap it over and send it?
Never rebuilt one of these before, so not sure. I've got it all torn down and going to start putting her back together soon as time allows.
FTI TW heads/FTI cam/RPMII/A-trim/T5 & 4.10's/QH w/ BE & EA/GUFB
www.carstereooneinc.com
fox88 is offline
post #2 of 3 Old 06-19-2019, 11:19 AM
Mustang5L5's Avatar
Yes, just reuse what you don't have. Only issue might be pulling the two bearings off the countergear shaft. I'd just google the bearing part numbers stamped on the bearing, and buy another pair. All of the bearings are standard, readily available bearings that are used in many other things besides t5's.
Bearing on the input shaft might be another one you just need to buy vs trying to remove it from your original shaft.
If i bought a 2.95 gearset, or an astroperformance gear set, i'd do the same thing
EvilGooses likes this.
Mike
--1988 Mustang LX 5.0--
Mustang5L5 is offline
post #3 of 3 Old 06-19-2019, 04:21 PM Thread Starter
fox88's Avatar
Cool. I have a 20 ton press in my garage, so I'm hoping I can do the bearing swap cleanly with that. We will see.
fox88 is offline
