Diagnosing in-op Cruise Control. 1990 GT - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 25 Old 06-14-2019, 03:34 PM Thread Starter
Nitrous SSC's Avatar
Cruise has been in-op for around 12 years or so. I'm sick and tired of it. I want god damn cruise. 1990 GT
Alright here's what I've checked...
VSS Good. Verified working via data logging.
Neutral Safety switch. Via clutch pedal works. Unsure if the one mounted on the transmission is part of the cruise system.
Brake pedal dump valve. Moved it so that it is flush and resting against the brake pedal as far as it can go.
Vacuum line from hose tree to fender is hooked up with no leaks.
Cruise/horn/lighter circuit good. Has power.
I remember long ago if I pushed off/on at the same time on the cruise my horn would honk. It doesn't do that anymore. My clock spring does have a small issue. It triggered an airbag code about 7 years ago. I just put a resistor in the column to simulate the airbag was plugged in and dis-connected the bag. There is no off the shelf clock spring specifically for a 1990. However I've read some people retro fit Dorman 525-201. I just ordered one and will have it tonight to install.
If I can verify the clock spring is sending correct voltage and signal to activate the unit.... then what? What's next?
Is there anything I can probe for a voltage signal in the column to verify the clock spring is sending the on signal to the module? The car is programmed not to activate cruise unless at 30 or above. In theory could I change this in Binary editor to say 5mph to make it easier to diagnose while the car is on jackstands and the wheels are spinning?
Thanks guys.
Bonneville 130 club member. (139.993) [email protected] in the 1/4.
Nitrous SSC is offline
post #2 of 25 Old 06-14-2019, 05:26 PM Thread Starter
https://mustangforums.com/forum/5-0l...or-module.html
I found this for diagnostics.
post #3 of 25 Old 06-14-2019, 06:13 PM
indy2000's Avatar
LET US know how that troubleshooting chart works
Sigmund never followed up that thread.
It’s pretty simple circuit, and the amplifier checks for 7volts on the monitor through the brake lights
If you have led brake lights you will not have cruise without a resistor simulating a filament bulb
indy2000 is online now
post #4 of 25 Old 06-14-2019, 06:23 PM Thread Starter
Itís pretty simple circuit, and the amplifier checks for 7volts on the monitor through the brake lights
Will do. I don't have LED anything except for my tag lights and cluster illumination lights.
Hopefully this new clock spring doesn't take too much modding to make work. A shame my 1990 needs a specific one.
post #5 of 25 Old 06-14-2019, 06:58 PM
indy2000's Avatar
you could convert to non airbag wheel and have tilt column put in
post #6 of 25 Old 06-20-2019, 08:03 PM Thread Starter
Update, that Dorman part wasn't going to fit. Not even close.
I was able to clean up and restore clock spring function to horn and cruise but not airbag. I tested the voltages in the column and all buttons are working correctly and sending correctly.
I have a spare module from a 92' that is in working order. I swapped it out today but no luck. I pulled the fender cover out and checked all the vacuum lines to the servo. They all work perfectly and the dump valve works correctly as well. So from here I'm going to check the resistances of the different circuits of the servo itself. This is going to SUCK BALLS because of where that damn pig tail is under the dash. My guess is the servo.
I remember a problem I had a long time ago.... My car had an electrical issue about 18 years ago where whenever I'd push the brake lights the fuse would pop. I had a shop fix it as I was not mechanically inclined then. When I got the car back the cruise control no longer functioned. I went to take the car back and the shop was out of business. The brakes lights were operational so I figured meh...who needs cruise anyway... I'm wondering if when I check the pins it will point me to an issue with the brake switch...
Back to under the friggin dash...
post #7 of 25 Old 06-20-2019, 09:44 PM
JV106's Avatar
Does your horn work? I had a penny stuck in my cigarette lighter and it took out that whole circuit for years. I felt like a king when I found it.
JV106 is offline
post #8 of 25 Old 06-20-2019, 09:57 PM Thread Starter
Yes, that circuit has power.
post #9 of 25 Old 06-21-2019, 02:45 PM
indy2000's Avatar
Make sure the cruise monitor circuit is not open or short to ground
It is integrated to the brake light circuit
If the repair removed that monitor the cruise will never turn on, it will be in a permanent off state
It also must go through the clutch sense switch, the switch that activated by the clutch pawl
post #10 of 25 Old 06-23-2019, 02:40 AM Thread Starter
Do you by chance know which pin/wire that is for me to check at the module?
post #11 of 25 Old 06-23-2019, 09:43 AM
indy2000's Avatar
R/LG wire from amplifier, from memory
pm a email, i will send you diagram of the circuit with pin number when i get home
post #12 of 25 Old 06-23-2019, 10:39 PM Thread Starter
Thanks Indy. madevilmustang(at)hotmail.com
post #13 of 25 Old 06-24-2019, 12:19 AM
indy2000's Avatar
sent
post #14 of 25 Old 06-26-2019, 04:40 PM Thread Starter
Alright here’s what I’ve got. The Red/light green strip wire is cut at my brake switch. I raced it to a pig tail inside the kick panel. It only has battery voltage when the brake is pushed.
With ignition on Checking the that red/light green wire at the amplifier it has a steady battery voltage. (I used a needle to poke it) If I push the brake no change other than a slight drop from the tail lights. From what I’m understanding this should only see voltage if the brake is pushed. Not all the time. Correct?
Also white/purple is getting battery voltage as well.
File Type: jpg F9B699B5-3668-44A1-8BD8-211A052F5F74_1561581341450.jpg (57.9 KB, 9 views)
File Type: jpg 7C1318B5-756E-4DD2-A4D5-45DD15137923_1561581481149.jpg (80.6 KB, 9 views)
File Type: jpg 9BDF469C-B2C1-4806-84FE-A7CF760921EE_1561581500018.jpg (57.5 KB, 9 views)
post #15 of 25 Old 06-26-2019, 05:41 PM
indy2000's Avatar
That wire puts out 7volts
With a proper brake light, that will be pulled to ground, that will tell the amp the clutch switch is closed
If the clutch switch is open or the brake light bulbs are open the 7volts will tell the amp ‘no cruise’
If you are in cruise, ie the brake lights are pulling the 7volts to ground
And you step on the brake pedal, that battery voltage to the amp will say no cruise just the same
Therefore, yes you should not see batt voltage to that pin unless the brake switch closes
Someone messed your wiring up
post #16 of 25 Old 06-26-2019, 05:44 PM
indy2000's Avatar
The amp needs to be powered
I will assume that white wire is the powering up circuit, just guessing
Wiring diagram is not in front of me
post #17 of 25 Old 06-26-2019, 06:01 PM Thread Starter
Update... I found the factory wire that was bypassed and tested it. No ground outs or anything. I hooked it back up and brake lights work fine. Not sure why the mechanic did that.
But the red with light green into the amplifier still has 12v. My brake lights aren’t on.
File Type: jpg 659DD895-3646-467D-8EEC-A99FF3180AFB_1561586399881.jpg (92.9 KB, 6 views)
post #18 of 25 Old 06-26-2019, 06:55 PM
indy2000's Avatar
does a test light light up?
does the 12volts still exist when you step on the clutch?
if you have 12volts on that wire, you have 12 volts at the brake lights
you have to.
post #19 of 25 Old 06-26-2019, 07:13 PM Thread Starter
Alright so here’s what’s weird. I used a test light as you suggested. At the pedal the switch works correctly and lights it up. Checking the wire at the amplifier it reads 12v but won’t turn the light on. I used both meter and light at the same time and when I do this it goes to Zero. I remove the light, back to battery voltage But when I push the brake down with all this hooked up, no light, no change.
What the hell......do I have another break in that wire somewhere and the amplifier is back feeding a tiny 12v signal?
I need a beer and a priest I’m thinking. I’m shot for the day my shoulders are hurting and my back is killing me. I’m half tempted to cut that damn wire at the controller and just rely on the vacuum dump to turn off the cruise.
post #20 of 25 Old 06-26-2019, 07:22 PM
indy2000's Avatar
remove the power feed to the amp
recheck the wire
post #21 of 25 Old 06-26-2019, 10:04 PM Thread Starter
Will do and report back. Thanks.
post #22 of 25 Old 06-26-2019, 11:01 PM
indy2000's Avatar
cutting the wire wont'd work by the way, it needs a ground
post #23 of 25 Old 07-06-2019, 09:06 PM Thread Starter
So I followed that online post and checked all of the ohms on my servo and everything checked out OK. I checked all the voltage at the controller and the wiring and that came out OK to. However when I use this troubleshoot method in the picture I cannot make the servo energize itself to test for function. I also cannot find any online resources on how to make sure that the cable is adjusted correctly.
God this sucks.
File Type: jpg 7C050DCD-DE28-4491-A8D0-A9C158ACB4C2_1562461464616.jpg (117.5 KB, 4 views)
post #24 of 25 Old 07-06-2019, 09:15 PM
indy2000's Avatar
i have the cable adjustment info
if you cannot bypass the amp, that indicates an open
did you fix the 12 volt problem
post #25 of 25 Old 07-06-2019, 09:29 PM Thread Starter
I figured out the little metal clip that I have to remove at the throttlebody linkage I pulled the access through until it was tight and then put the clip back in. It moved a solid inch Of play.
