Headliner Coupe Effort - Ford Mustang Forums : Corral.net Mustang Forum
 3Likes
  • 1 Post By 90trunk
  • 1 Post By Leadsled Coupe
  • 1 Post By TurboCoupe1
post #1 of 15 Old 04-13-2019, 01:11 PM Thread Starter
Leadsled Coupe's Avatar
Well I took out my headliner. Easy over all. MESSY yes.
What do you all recommend to go in above the new headliner? Dynamat or some Lowes generic mat? What about something reflective to keep heat out?
Secondly do I need to remove this plastic glued on sheet all the way? If I scrape it I am afraid I’ll damage the thin sheet metal.
File Type: jpg 7070F27A-E695-4E75-B16E-14324DC79ED3_1555175488802.jpg (56.9 KB, 30 views)
Si vis bellum para pacem
Alphabet Soup- Manual Lentech AOD, 3krpm stall UCC, MM TA PHB, CC-CO, AFR, FTI, LTH, 3.73, 333ci/ 420fwhp, S197 mufflers.
Leadsled Coupe is offline
post #2 of 15 Old 04-13-2019, 01:19 PM Thread Starter
One more pic.
File Type: jpg A4797C50-A997-49C1-975D-95F686962366_1555175971732.jpg (81.5 KB, 35 views)
post #3 of 15 Old 04-13-2019, 02:00 PM
I need to do the same thing to mine, I’ll be using stuff from Lowe’s. It’s called Frost king and is adhesive on one side and foil on the other.
5.0carlo is offline
post #4 of 15 Old 04-13-2019, 03:54 PM Thread Starter
I wonder if all of this stuff still in my roof will come off. I suppose I’ll hit it with a soft bristle brush. Whatever doesn’t come off can stay.
post #5 of 15 Old 04-14-2019, 04:54 PM Thread Starter
Eh... what didn’t brush off nor wipe off with brake cleaner can stay. Then installed one roll of peel n seal. Covered whole top with one extra strip. Think I’ll go two layers as it still sounds a wee bit tinny.
PS- yep two layers on now. This should be nice and quiet. 8-)))
File Type: jpg 47EE1192-ADB2-4E6E-AE1E-FE85D2526DC9_1555275184020.jpg (47.9 KB, 21 views)
File Type: jpg 4CE92D00-6CE6-443D-8796-6E3DB17A4D0E_1555275266406.jpg (49.3 KB, 22 views)
post #6 of 15 Old 04-14-2019, 04:57 PM Thread Starter
Also putting a little anywhere I see exterior metal. Should help with sound for sure. Rearware of quarter window on one side.
File Type: jpg B5780C08-922F-440B-B443-8DF7C1550B2E_1555275443215.jpg (57.0 KB, 23 views)
post #7 of 15 Old 04-14-2019, 11:28 PM
90trunk's Avatar
I added 50% coverage of Noico and 2 layers of EZ Cool insulation on my roof when I had the headliner removed. I noticed the AC did a much better job last summer. My takeaway is the roof is a giant heat sink and the insulation was helpful.
I also did the rear seat area while I was there. I had done the floor from the firewall to the trunk in EZ Cool a few years earlier. Anything you add to these for sound dampening and insulation is a plus.
File Type: jpg 1832A68E-03AF-41EE-9DE4-BD1DE6BF1063_1555298818729.jpg (125.1 KB, 27 views)
File Type: jpg 472710FC-3E01-4AA3-99A7-E44FD1E885B3_1555298851436.jpg (77.4 KB, 26 views)
File Type: jpg 6FA75A68-1AF9-4ABF-A8D8-2B66641B03CC_1555298903126.jpg (103.1 KB, 26 views)
File Type: jpg A1D4065F-DF07-4585-B489-F1ED30570256_1555298915827.jpg (74.6 KB, 26 views)
Regards,
Craig
[email protected] at Milan,3450#...
Dynojet'd 286rwhp/331rwtq Stock Cam, GT40 Irons
90trunk is offline
post #8 of 15 Old 04-15-2019, 04:13 AM Thread Starter
Great info thank you.
It looks like that company is out of business but they recommended this one.
http://www.carinsulation.com/buycarinsulation.html
I’ll call them up. Great idea. I wondered what I was going to do in the corners where the fiber mat was. I like the idea of using behind the rear seat as well.
post #9 of 15 Old 04-15-2019, 11:53 PM
90trunk's Avatar
Automotive Heat & Sound Car Insulation Store
Iíll call them up. Great idea. I wondered what I was going to do in the corners where the fiber mat was. I like the idea of using behind the rear seat as well.
I purchased my EZ Cool through Amazon. The carinsulation.com product is the same item though.
https://www.amazon.com/Ez-cool-Insul...s%2C425&sr=8-3
Here's a great tech page on an EZ Cool install with before/after results;
citroen cx insulation
I had extra Noico left over, so I covered both of my doors and added a layer of EZ Cool to the back of the door panels. I wish I had documented some before and after results with my decible meter. It's not like i was trying to turn the car into a Lincoln, but I feel the insulation and dampening project was time well spent, especially if you have the interior removed. I'm glad you found the pics and info helpful.
xporter likes this.
Regards,
Craig
90trunk is offline
post #10 of 15 Old 04-16-2019, 12:09 AM
90trunk's Avatar
Noico and EZ Cool on the doors...
Edit: Do your package tray too if you haven't!
File Type: jpg 1311120B-AD2C-4464-9556-74D4A84D002D_1555387725382.jpg (102.3 KB, 19 views)
Regards,
Craig
90trunk is offline
post #11 of 15 Old 04-19-2019, 08:56 AM Thread Starter
Great work. I have some product coming and will do the trunk/rear seat area and package tray for sure. Also the areas under the inner rear panels. If I have enough I may add a layer above the headliner? Depends, that’d be two layers of peel n seal and one of this! If I like it I’ll buy more and do the doors and floor if I get a new carpet one day. Mines still good so there’s no rush.
90trunk likes this.
post #12 of 15 Old 04-20-2019, 07:26 AM
I used some generic matting from Lowe’s. I live in Florida. It definitely helps keep the heat out of the car when the sun is beating down on the roof. I used to be able to feel a temperature difference with the old headliner. With the new one and matting it’s kept cooler.
90trunk likes this.
TurboCoupe1 is offline
post #13 of 15 Old 04-20-2019, 07:59 AM
Any issues with panel fit over this stuff? For those that have used the above product how much did you need? I’d like to cover everything I can....roof, doors, floors, side
Gixx06 is offline
post #14 of 15 Old 04-20-2019, 11:46 PM
90trunk's Avatar
Originally Posted by Gixx06 View Post
Any issues with panel fit over this stuff? For those that have used the above product how much did you need? Iíd like to cover everything I can....roof, doors, floors, side
I bought a 200 sq.ft. roll of EZ Cool and I have a bunch left over. The door panels were a tight fit, as I had previously added LMR's noise dampening foam to the door panel. Everything else was problem free.
Regards,
Craig
90trunk is offline
post #15 of 15 Old 04-22-2019, 08:41 PM Thread Starter
I did two layers of peel n seal. PLENTY of room to spare.
For Sale ***M90 supercharger completekit off 91 sc for 94/98mustang v6 Everything included** blackmustang98_ Power Adders 2 12-13-2010 03:10 PM
FS black coupe headliner and dome light papis408 Interior Parts 9 01-27-2010 09:22 PM
Difference between coupe and hatch headliner for foxbody? svtcobra2k1 General Mustang Tech 4 11-26-2008 10:21 PM
WTB 87-93 black coupe headliner FreakingStang Interior Parts 5 07-13-2004 11:07 PM
Headliner for Mustang coupe 700srx Interior Parts 0 06-05-2004 08:01 PM
