Hey Indy was just wondering if you're running a T56 with a single disk clutch, and if you know if there were any shims used?... Thank you for the reply
I have a single disc full face Monster level 2 with my T-56. I had to use 2 shims for my slave/tob. I ordered the Tick shim kit before the install and shims were definitely needed. Its different for all setups. The shop really should have measured. What happens is the slave ends up over extending its self and can go bad quick. Properly setup they should last a long time.
i had to machine the stock bearing retainer to get within mcleod’s posted tolerance
Related Threads
Ford Mustang Forums
9.8M posts
200.8K members
Since 2001
