Dual plane manifold carb tuning - Ford Mustang Forums : Corral.net Mustang Forum
 3Likes
  • 1 Post By Saleen414
  • 2 Post By Jack Hidley
post #1 of 20 Old 04-12-2019, 06:31 PM Thread Starter
Flfox81's Avatar
I need some carb tuning advice here. I recently swapped out my Weiand 7515 intake manifold which is single plane, for a stealth that is duel plane. I am running a 302 w/p heads, N41 cam with full bolt ons and holley double pumper 650 w/ mechanical secondaries. Since the swap it runs lean.Timing is at 14 degrees. The car starts right up, idles at 850 at around 13.1 on the wideband. Starting off from a stop, with light throttle and load the wideband rolls right over to 14, 15, 16 as the throttle increases. Car obviosly starts bucking.
I have never had this much of an issue dialing in my carb. Is it normal to have to increase jet size or power valve for a dual plane?
Any advise would be great. I need to drive it before it gets much hotter.
Flfox81 is offline
post #2 of 20 Old 04-12-2019, 07:13 PM
Saleen414's Avatar
Normally a dual plane manifold will be jetted leaner than a single plane intake. Are you sure that there are no vacuum leaks?
Clarence Harris likes this.
26 X 8.5 Hoosier
Saleen414 is offline
post #3 of 20 Old 04-12-2019, 07:19 PM Thread Starter
Flfox81's Avatar
Yeah, i went over every fitting and sealed area with a can of carb spray. The dual plane is a lot taller
Flfox81 is offline
post #4 of 20 Old 04-12-2019, 08:02 PM
Bump......I'd like to hear more about this. Someone chime in
Sent from my SM-G970U1 using Tapatalk
laramik is online now
post #5 of 20 Old 04-12-2019, 08:54 PM Thread Starter
Flfox81's Avatar
I was just thinking about it, the only I forgot was that I do have a 1" phenolic spacer, that is open. I have heard 2 different arguments about using it with this kind of manifold. I haven't heard of anyone else having these problems though.
Flfox81 is offline
post #6 of 20 Old 04-12-2019, 09:46 PM
dual plane intake pulls better vac. lean out by a jet or 2 sizes
Clarence Harris is offline
post #7 of 20 Old 04-12-2019, 10:19 PM Thread Starter
Flfox81's Avatar
I'm confused now. Wouldn't I up the jet size to eliminate the increase in vacuum causing the lean mixture?
Flfox81 is offline
post #8 of 20 Old 04-12-2019, 11:43 PM
Jack Hidley's Avatar
If the car is idling at 13:! a/f ratio it isn't lean, it is rich. Fix that problem first. Always start with optimizing the steady state conditions before moving onto the transient conditions.
If the mixture moves in the direction of lean during acceleration, then the carb is not supplying enough fuel for these conditions. If it does this a little bit in reaction to small throttle inputs, it is going to be the main jets. If it goes in the direction of lean much faster when the rate of throttle change is increased, then the accelerator pump is not supplying enough fuel. Since a dual plane intake manifold has more runner length, it has more total surface area. This will always require more accelerator pump volume to compensate for the wetting of the increased area. If you are using a carb spacer, that increases the surface area even more.
tjm73 and laramik like this.
Jack Hidley
Jack Hidley is offline
post #9 of 20 Old 04-14-2019, 04:57 PM Thread Starter
Flfox81's Avatar
I purposely run it a little fat on idle. I took 67 main jets out and put in 69s and a 4.5 power valve. With the cam I get a best of 10" of vacuum. I did re adjust the idle screws also, idles at around 14.5- 15 on the wideband. Just light throttle rev in the driveway, it leans out. I don't understand what the deal is. I have never had this much trouble with tuning this setup. The car ran awesome with the other intake. I had this one lying around and had heard good things about it. I'm sure where to go from here. Anyone else have any ideas here.
Flfox81 is offline
post #10 of 20 Old 04-16-2019, 11:28 AM Thread Starter
Flfox81's Avatar
Bump Bump
Flfox81 is offline
post #11 of 20 Old 04-16-2019, 01:53 PM
I run this exact same setup in the race car, the only difference being ported AFR 165s and a .5Ē spacer. As Jack said, you need bigger jets.
My setup: 78 mains, 74 secondary, 40 main squirted, 31 secondary squirters. The main body has changeable air bleeds, not sure if yours does or not.
Mustang415 is offline
post #12 of 20 Old 04-16-2019, 04:00 PM
Curt C's Avatar
Are the accelerator pumps / squirters working properly? You rev it in neutral and its leaning out / stumbling?
1986-045 Saleen Mustang Griggs GR40, 408W RDI aluminum block, AFR 205, T56
1999 Porsche 911 Carerra - Stock
1999 BMW M Coupe - Stock
Curt C is online now
post #13 of 20 Old 04-16-2019, 04:14 PM Thread Starter
Flfox81's Avatar
Mustang415....I have larger jets, thank you i will add my 74 jets when i get home.
Curt C......I checked adjustment and operation and both look good. I removed the nozzles and there is no crap, and are squirting normally. In the driveway it a quick rev to about 3k it starts to lean out. If i adjust the idle screw out some it is fine until under load. I have gone over the entire manifold looking for vacuum leaks.
Flfox81 is offline
post #14 of 20 Old 04-16-2019, 04:35 PM
I always read your posts 2 or 3 times. Your depth of knowledge is impressive and your delivery is very practical without sounding like a jerk. I almost always pick up something I didn't think of or that was not directly part of the question you are responding to from your posts too.
ie the wetted surface impact on accelerator pump sizing.
tjm73 is online now
post #15 of 20 Old 04-16-2019, 05:50 PM
Curt C's Avatar
Fattening the idle mixture can help crutch the job of the accelerator pump (transition between idle to throttle). I assume it goes lean again once you get under load even with a rich idle?
post #16 of 20 Old 04-16-2019, 05:59 PM Thread Starter
Flfox81's Avatar
That is exactly what happens.
Flfox81 is offline
post #17 of 20 Old 04-16-2019, 08:50 PM Thread Starter
Flfox81's Avatar
Thanks guys for all your advice. I got home and threw in a set of 74 primary jets. It is running rich now, at idle. Which is no big deal because I can dial that out. When given slow easy throttle, it will stay within a decent balance on the wideband. Although, when punch it quick it will lean it again. So, what do I need to do to the accelerator pump? It is properly adjusted. Should I upgrade to the 50cc pump or up the squirters? Thanks again, I do appreciate your advice.
Flfox81 is offline
post #18 of 20 Old 04-16-2019, 09:09 PM
Up the accelerator pump nozzle size. You can fine tune it by changing the accelerator pump cam. For the cams, One end of the spectrum would be a big shot up front that ends fairly quickly. The other end of the spectrum is a smaller shot but over a longer period of time. See what the car likes with a bigger nozzle first (dont go past a 35 without upgrading to the 50cc diaphragm ), then fine tune with the different cam profiles if you need to.
GTO44 is offline
post #19 of 20 Old 04-16-2019, 09:31 PM
Curt C's Avatar
Are you actually driving it or just punching it in neutral? Go drive it safely and advise how it acts. You canít really diagnose drivability and transition punching it in neutral. Make one change at a time or you will get lost in the forest real quick. Go slow.
post #20 of 20 Old Yesterday, 11:23 PM
Seems like if you changed the mains, and the idle mixture went rich, you've got another issue. The mains shouldn't affect the idle mixture unless the throttle is open a good bit at idle-i.e.-exposing the the majority of the transitions. Do you have 4 corner idle?
Am I right? Been a while since I messed with a Holley.
WTT my '92 GT for a nice clean '91-'93 2.3/T5 hatch or coupe.
toddturbo is offline
WTB: Carb Dual Plane Intake Manifold quick50stng Windsor Engine Parts 1 06-21-2016 02:10 PM
10:1 Street 408C for Mike Drew Daniel Jones 351C/Big Block Engine Tech 0 09-07-2015 05:27 PM
Budget 351C Rebuild and Dyno Test Daniel Jones 351C/Big Block Engine Tech 5 09-07-2015 05:22 PM
For Sale The Ultimate Ford EFI Tuning Guide: (Binary Editor/SCT/Delta Force/HP Tuners) PowerAdder Solutions Advertiser's Showcase 50 08-20-2014 05:01 PM
carb intake question single plane or dual plane for weekend warrior 94503 5.0/5.8 Engine Tech 4 11-11-2006 01:32 PM
