Timing light question - Ford Mustang Forums : Corral.net Mustang Forum
 6Likes
  • 1 Post By Saleen414
  • 1 Post By indy2000
  • 1 Post By Dave_B
  • 1 Post By stangjumper
post #1 of 13 Old 04-02-2019, 09:33 PM Thread Starter
351
I have a 92lx and I am in the process of attempting my first start with a Holley hp stand-alone ecu. I went with a dual sync distributor and I need to check timing.
This is where the joke comes. I have never checked timing before and even watching the YouTube videos of it, I still have questions about doing it right.
My ecu will control the timing, but I have to make sure it matches what the ecu is telling it to be.
What do I do? I am running the msd6al2, tfi coil, dual sync distributor.
Do I just buy a cheap To midrange timing light and play with it until I find out how to use it?
Whatís weird on the dual sync distributor is that it goes in 50 deg before top dead center.
Any ideas guys?
351 is offline
post #2 of 13 Old 04-02-2019, 09:41 PM
indy2000's Avatar
disconnect the ECM wire, SPOUT, that goes to the ignition module
and set it.
indy2000 is offline
post #3 of 13 Old 04-03-2019, 08:36 PM Thread Starter
351
Can anyone else explain it like Iíve never done this before please?
351 is offline
post #4 of 13 Old 04-03-2019, 09:00 PM
Saleen414's Avatar
First off I have to know if you are using a crank trigger and if the dist is now a cam sync. The answer to that changes how you set and verify timing.
351 likes this.
26 X 8.5 Hoosier
Saleen414 is offline
post #5 of 13 Old 04-03-2019, 09:22 PM
indy2000's Avatar
your holley must have an output that goes to the ignition module, severe it
351 likes this.
indy2000 is offline
post #6 of 13 Old 04-04-2019, 07:33 PM Thread Starter
351
No crank trigger, dual sync now is a cam sync.
Innova told me none of their timing lights would work with my msd6al2.
ETA: Iím trying to check timing before first start of my Holley hp ecu. Ecu would control it but Iím trying to follow the instructions and see if timing is spot on or close.
351 is offline
post #7 of 13 Old 04-05-2019, 07:13 AM
Saleen414's Avatar
There should be a fixed timing test you can perform. You enter in how much timing you want the engine to have, apply that setting, and the ecu keeps it at that amount regardless of rpm and you then check with a timing light if the amount you have commanded is the same as the timing light shows.
351 likes this.
26 X 8.5 Hoosier
post #8 of 13 Old 04-05-2019, 11:43 AM Thread Starter
351
Yes sir, thatís what Iím trying to do.
351 is offline
post #9 of 13 Old 04-05-2019, 04:34 PM
[ETA: Iím trying to check timing before first start of my Holley hp ecu. Ecu would control it but Iím trying to follow the instructions and see if timing is spot on or close.[/QUOTE]
If you truly mean you want to check it with the light BEFORE first start... You can't, it has to be running. Not sure how to tell you how to make sure it's in the ballpark with that distributor.
351 likes this.
Dave_B is offline
post #10 of 13 Old 04-05-2019, 05:15 PM
Trader Feedback: (41)
Why does the engine have to be running? Pull the fuse to the fuel pump or turn the pump output off in the software if you can. When you crank the engine the coil will fire.
I haven't looked at the holley software in awhile. There should be an ignition timing table for idle. If not just make the lower rpm/load cells the same timing value so it won't change when checking.
351 likes this.
stangjumper is offline
post #11 of 13 Old 04-05-2019, 10:13 PM Thread Starter
351
If you truly mean you want to check it with the light BEFORE first start... You can't, it has to be running. Not sure how to tell you how to make sure it's in the ballpark with that distributor.[/QUOTE]
Thank you for the reply. Instructions on distributor and ecu state to turn it over and check timing with injectors unplugged
351 is offline
post #12 of 13 Old 04-05-2019, 10:15 PM Thread Starter
351
Yes sir they have the table in the software. Holley days to check and see that the new dual sync distributor matches what the ecu is commanding.
Iím just trying to follow what they ask for, Iíve already messed many things up on my way to install this stand-alone.
351 is offline
post #13 of 13 Old 04-10-2019, 06:31 PM
Just thinking about my statement. There should be a cranking ignition table that the ecu uses only during cranking. This is the value you will be looking for on the damper if you remove the fuel. It will crank but not start.
351 likes this.
How To Retrofit HID Projectors Into New Edge Headlights Cougarstang General Mustang Tech 24 10-15-2010 12:47 PM
How much posts do i need to post a for sale ad? Jakashh Lounge 105 02-10-2010 04:44 PM
Wilson: U.S. Security Put at Risk sivnalem Politics 96 11-16-2005 05:56 PM
Who makes a good timing light for around $50 and another question or two?? FastGT94 General Mustang Tech 4 04-14-2004 12:12 PM
newbie question - timing timster121 5.0/5.8 Engine Tech 1 07-11-2003 03:25 PM
