Whos done LED head light/tail light bulbs? - Ford Mustang Forums : Corral.net Mustang Forum
 6Likes
post #1 of 133 Old 01-26-2019, 01:23 PM Thread Starter
Striker01's Avatar
With stock head light/tail light housings?
Just wondering if changing over to LED bulbs is a worthy investment? I wanted to do all the exterior bulbs with LEDs
Striker01 is offline
post #2 of 133 Old 01-26-2019, 01:48 PM
indy2000's Avatar
headlights are not good up to now
i have converted to HID projector Bixenon for headlights back '06
all other exterior lights are philips LEDs
I went from ~18amps to less than 2amps
for all exterior lighting minus the headlights
indy2000 is offline
post #3 of 133 Old 01-26-2019, 08:11 PM
is there any that's good now?
toddturbo is offline
post #4 of 133 Old 01-26-2019, 09:12 PM
indy2000's Avatar
not for fox housings
lots of reasonably good ones for newer vehicle retrofits, includes proper housings
non still compare to xenons that i have compared
indy2000 is offline
post #5 of 133 Old 01-27-2019, 05:24 PM
Stangdawg's Avatar
Where did you buy the LEDs?
1989 GT - 347 build in progress
Stangdawg is offline
post #6 of 133 Old 01-27-2019, 06:07 PM
indy2000's Avatar
local parts supplier called lordco
should be avail from any local supplier
https://www.usa.philips.com/c-m-au/car-lights/turnon
indy2000 is offline
post #7 of 133 Old 01-28-2019, 05:49 AM
Ryno22980's Avatar
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
These work, but you have to modify your lock ring due to the wiring coming off the side. I wound up breaking my lock rings as they were brittle, and just super glued the bulb to the housing. Replacement fox housings are cheap enough that I didn't sweat it. These LEDs are much brighter but not blinding to other drivers.
Keep in mind that if you do LED blinkers and markers, you will likely need new flashers for both to work. Check out superbrightleds.com for those.
Ryan O.
'89 GT Vert
Ryno22980 is offline
post #8 of 133 Old 01-28-2019, 09:38 AM
Mustang5L5's Avatar
I bought a set of Phillip's Ultinon LED bulbs for the rear taillights. As soon as i wrap up my current project, i plan to install the LED's in one taillight and see what difference they make.
I've used some of the random china bulbs before and they were nowhere near as bright as OEM bulbs, so out they came.
Mike
--1988 Mustang LX 5.0--
Mustang5L5 is offline
post #9 of 133 Old 01-28-2019, 09:58 AM
indy2000's Avatar
i hope you painted the silver deflector white
indy2000 is offline
post #10 of 133 Old 01-28-2019, 10:02 AM
indy2000's Avatar
i do not know the brightness difference
but those are 60W, wow........
also they use a fan, so will require cleaning periodically
indy2000 is offline
post #11 of 133 Old 01-28-2019, 10:50 AM
Mustang5L5's Avatar
I did that many years ago. Made a huge difference in light output with the OE bulbs
Mike
post #12 of 133 Old 01-28-2019, 04:22 PM
Ryno22980's Avatar
Thanks for the heads up. I would hope a little compressed air would suffice.
Ryan O.
'89 GT Vert
post #13 of 133 Old 01-28-2019, 08:28 PM
indy2000's Avatar
i wouldn't rely on some cheap little fan
indy2000 is offline
post #14 of 133 Old 01-28-2019, 08:35 PM
Ryno22980's Avatar
Considering they cost less than $25 and it's not my daily driver, I'm okay with the gamble. The car sees maybe 1500 miles a year.
Ryan O.
'89 GT Vert
post #15 of 133 Old 01-28-2019, 09:16 PM
thadude's Avatar
If that's the case why not just do this, solve the issue and call it a day? https://ceautoelectricsupply.com/hea...ht-relay-kits/
1993 Cobra #1282
thadude is offline
post #16 of 133 Old 01-28-2019, 09:52 PM
indy2000's Avatar
you are correct, its just money
indy2000 is offline
post #17 of 133 Old 01-29-2019, 06:01 AM
Ryno22980's Avatar
That kit is $150 and a good chunk of time to install. If I have a problem with what I got, I would ditch the LED bulbs and go back to stock like bulbs before I would pay that.
Ryan O.
'89 GT Vert
post #18 of 133 Old 01-30-2019, 12:14 PM Thread Starter
Striker01's Avatar
So is there a kit that would do all the lights on the car to LED?
post #19 of 133 Old 01-30-2019, 12:22 PM
indy2000's Avatar
Try lmr
Also realize when the brake lights are led
You will lose cruise control
Unless you know how to solve that
indy2000 is offline
post #20 of 133 Old 01-30-2019, 06:37 PM Thread Starter
Striker01's Avatar
Ripped cruise control out so that wont be an issue.
post #21 of 133 Old 01-30-2019, 07:43 PM
indy2000's Avatar
you can pick out all the bulbs you need from superbright led
indy2000 is offline
post #22 of 133 Old 01-31-2019, 12:23 AM
Uhhh, id have to disagree with the comments saying LED headlights suck. I was on the fence as well, and finally installed some hikari bulbs from amazon. $30 to my door, and the light spread and brightness is fantastic. I hate to drive my other vehicles with halogens at night now. My car is an 02 with factory style housings, no modifications needed. I would do it again in a heartbeat, considering theyre the same cost as halogen bulbs. Been running them for months now, no issues
Treston Hadley is offline
post #23 of 133 Old 01-31-2019, 02:01 AM
I first did a E4 upgrade to my 1987 Mustang about 20 years ago. Then a couple years later I upgraded them to HIDs.
https://goo.gl/photos/iK7t3JLWzHxyfDGE7
I've been using them ever since, waiting for a good set of H4 LED replacements, but I've never read a good review of them.
I also did some LED mods to my 1969 Mustang:
https://photos.app.goo.gl/H9Cwiue1zcVMsn5Y7
The backup light have always been horrible, but my first LED drop-in replacement only made a lot of light, but did not provide any improved illumination. I modified some MR16 lights to fit into the housing, and they worked a lot better.
I used LED replacements for the H1 high beams, and as expected, they're extremely bright, but I think the focus patterns are pretty poor. I have a set of highly recommended H4 LED bulbs, but I haven't tried to replace them yet.
eycchu is offline
post #24 of 133 Old 02-03-2019, 02:19 AM
Leadsled Coupe's Avatar
Interesting, why do you loose cruise with led brake light use?
Si vis bellum para pacem
Alphabet Soup- Manual Lentech AOD, 3krpm stall UCC, MM TA PHB, CC-CO, AFR, FTI, LTH, 3.73, 333ci/ 420fwhp, S197 mufflers.
Leadsled Coupe is offline
post #25 of 133 Old 02-03-2019, 07:44 AM
Ryno22980's Avatar
Has to do with how the cruise turns off when you press the brake pedal. Read Indy's post (#18) on the thread below.
https://forums.corral.net/forums/gen...il-lights.html
Ryan O.
'89 GT Vert
post #26 of 133 Old 02-03-2019, 08:38 AM
indy2000's Avatar
the cruise module produces 7volts
normally this is grounded through the normal brake light, incad
when the cruise module sees this 7volts it thinks the clutch pedal switch is open, ie you are stepping on it.
the led doesnt provide the ground path to allow the 7volts to go to 0 zero volts
i haven't tested my solution, so i haven't posted it yet, car is up in the air now
should have a solution for the summer.
indy2000 is offline
post #27 of 133 Old 02-03-2019, 11:09 AM
Ryno22980's Avatar
[/quote]
should have a solution for the summer.[/QUOTE]
In your post from the link I posted, you said adding a small resistor in parallel to ground at connector 291 in circuit 810 would fix it. Is that the fix you are planning to test?
Ryan O.
'89 GT Vert
post #28 of 133 Old 02-03-2019, 06:46 PM
indy2000's Avatar
sort of
indy2000 is offline
post #29 of 133 Old 02-05-2019, 02:35 PM
I installed LED's on my headlights. The installation was easy and only took about 15min or less for both headlights. Visibility at night or during rain is a lot better now.
super777 is offline
post #30 of 133 Old 02-07-2019, 11:50 PM
Ramos617's Avatar
Haven't implemented LED in my headlights but i do know that installing a resistor between the bulb power wire and ground wire will fix flashing/signaling light issues and quite possibly the cruise control issue due the the difference in resistance across the OE bulb vs LED(less resistance).
I had HID bulbs in my headlights for a while and that was an absolute no go, first off you will need to implement headlight relays due to voltage drop/resistance and converting the headlight switch to an actual signal setup, not an inline series approach. My headlights were just too dam bright due the halogen bulb designed headlights and i even aimed them lower, attempted a projector retrofit but it was extremely time consuming. Great project BTW. So I ended up just pulling the hids for some almost pure white halogen bulbs which perform great with the relay mod. may look at LED for my main headlights in the future but HIDS im my car were just too bright and I stated to dislike being that guy with the super bright headlight blinding everybody haha.
Picture of HID retrofit about 40% completion, lost intrest and ended up selling the whole project (1987 t-bird, so no luxury of aftermarket headlights at all. only fluted style stocks)
https://photos.app.goo.gl/QeWLS8uzHtWWpCaAA
1989 Mustang GT
1987 Thunderbird Turbo Coupe
Ramos617 is offline
post #31 of 133 Old 02-08-2019, 08:39 AM
indy2000's Avatar
electronic flasher will eliminate the need for a load resistor, this will be for the signals
the cruise is part of brake light circuit
a resistive load is needed for cruise
indy2000 is offline
post #32 of 133 Old 02-10-2019, 12:46 PM
midnightlaundry's Avatar
I did the Dash and Headlights last year. The Headlights are still the bomb, so bright. The Highbeam setting doesn't really do anything and it's not really needed. Nobody has flashed me the brights so they're not out of adjustment.
I still haven't gotten a bright enough Dome light tho..
https://forums.corral.net/forums/gen...sh-lights.html
midnightlaundry is online now
post #33 of 133 Old 02-10-2019, 01:12 PM
I'll try these for the Dome and whatever.
post #34 of 133 Old 02-10-2019, 04:07 PM
Here's a vid explaining the resistor across power and ground.
https://www.amazon.com/dp/B00L4V9ECY...v_ov_lig_dp_it
post #35 of 133 Old 02-10-2019, 04:50 PM
indy2000's Avatar
putting load resisters in defeats one advantage, low current draw
electronic flasher, no load resistor needed
also using a load resistor, will defeat the hyperflash or warning that the bulb is out.
indy2000 is offline
LED tail light bulbs toddturbo General Mustang Tech 37 01-09-2019 09:19 AM
LED Bulbs at RockAuto.com! RockAuto RockAuto 1 05-26-2017 03:07 PM
led tail light bulb resistor question IRSmart GT & SOHC 2 03-15-2011 11:13 PM
99-04 blue and purple head light bulbs 2 sets... BMF03 Exterior Parts 3 07-30-2006 11:40 AM
