We have a new tank that should start shipping around November 5, 2012 and we are taking orders now. The new tank is a baffled design similar to what you would find in the 03/04 Cobra's. This is a brand new tank and not used
$279 + Shipping
If your interested in ordering, PM me, email at On3Performance@aol.com or you can always call
Foxbody guys:
This is a bolt in tank for your 96-04 Mustang and also can be used in the earlier Mustangs as well. I personally am running the same tank in my 90 Fox along with our fuel hat/pump setup. Using the tank in these application, it would require you to purchase and modify a filler neck from the 99-04 car. With my car I wanted to have a fuel system capabile of supporting pretty much as much power as I would want without having to upgrade. With this setup, that was accomplished and also was able to maintain a factory look. Looking at my car, you cannot tell that the tank or fuel system is even upgraded. No loud external pumps and a sleek look. Depending on the popularity of this, we will consider producing a filler neck to make this a direct drop in for the fox.
Fuel lines:
Also we have a good inventory stocked for all your fuel line needs as well. We have -8 and -10 braided black fuel line and most -8 and -10 fittings you would need for the entire fuel system. I will be putting a catalog together with all the fittings we can supply in the near future. Also we will be putting together a complete fuel system as well which would contain:
- On 3 Performance Baffled Fuel Tank $279
- On 3 Performance Triple Fuel Hat $279 New 2nd Gen
- Fuel Pump Options (On 3 Performance or Walbro) $90 / $99
- Injectors (FMS 39 $269, Bosch 42 $329, Deka 60 $350 or 80)
- Fuel Level Sensor $69
- Black Braided Nylon Fuel Line $4.50 Per foot
- Fittings - All Anodized Black
- Fuel Filter
- Regulator (Aeromotive Standard In All Kits) Price Depends on which model
- Rails
Also if you have certain items and needed most of a kit, thats not a problem either. We will be able to really put any system together just depending on your request and parts availability.
$279 + Shipping
Foxbody guys:
Fuel lines:
- Fuel Filter
- Rails
