For Sale 83 lb/hr fuel injectors - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 10 Old 11-23-2010, 10:50 PM Thread Starter
1BAD98's Avatar
Arrow 83 lb/hr fuel injectors
These injectors flow 86 lbs/hr at 43.5 PSI ( 3 BAR )
Need to sale my used fuel injectors, used for 360 miles and in very good condition. I needed bigger injectors. I made around 900 rwhp with these injectors. New they run $450.00-$500.00, I am asking $210.00 shipped.
FEATURES:
Genuine, reliable Siemens Injectors
Excellent response characteristics
Robust Design
Low Impedance
Specifications:
Coil Resistance: 2.35 Ohms / Low Impedance / Low-Z (Peak/Hold driver circuit required)
Static Flow Rate @ 43.5PSI ( 300kPa ) w/Gas: 86.2 lb/hr = 888 cc/min = 652.2 g/min
Connector: Bosch EV1
Spray Pattern: Pencil
Factory fitted with Viton upper and lower o-rings
Equivalent Part Numbers:
Siemens FI11405 ( 3105 )
Sold Supercharged 98 Cobra, FFR Cobra, turbocharged 408W Dart Iron Eagle block 225 AFR race heads. 83mm T6 turbo. Dyno numbers 924rwhp / 986rwtq In a car that weighs 2,270 lbs.
1BAD98 is offline
post #2 of 10 Old 11-26-2010, 11:00 PM Thread Starter
1BAD98's Avatar
Price lowered to $210.00 shipped. I also changed price above. Thanks
1BAD98 is offline
post #3 of 10 Old 12-03-2010, 09:12 PM Thread Starter
1BAD98's Avatar
Have not sold these yet! Only 360 miles on these things.
1BAD98 is offline
post #4 of 10 Old 12-03-2010, 11:43 PM
fmaster7's Avatar
damn what would you use these on, twin turbo? And you needed BIGGER? free bump
fmaster7 is offline
post #5 of 10 Old 12-06-2010, 12:28 PM Thread Starter
1BAD98's Avatar
These were in my 65 Cobra replica and at 850-900rwhp they are at there safe limit so I added 120 lb/hr injectors now I should have lots of room to grow!!! Thanks here is a picture of the car. -------------------
1BAD98 is offline
post #6 of 10 Old 12-06-2010, 01:13 PM
Mighty Mouse's Avatar
Trader Feedback: (52)
Not to hijack your thread, but what are you running EFI wise with that combo and how is the drivability with it?
I am doing a similar build - but running E85.
1986 GT Convertible Fordstrokers 445, High Ports and Super Victor Intake by Duane Busch, Holley HP EFI, and Team Z Suspension.
Mighty Mouse is offline
post #7 of 10 Old 12-06-2010, 06:27 PM
will these work on a 2004 mustang gt
Bpohlman13 is offline
post #8 of 10 Old 12-06-2010, 11:22 PM
Ill take them if they fit my car. Please email me at [email protected]
post #9 of 10 Old 12-10-2010, 10:26 AM Thread Starter
1BAD98's Avatar
Mighty Mouse, I am running Big stuff 3 fuel management system the the drivability is great, even big injectors. Bpohlman13, They will fit the car but I think you will need the EV1-EV6 plug adapters.
1BAD98 is offline
post #10 of 10 Old 12-11-2010, 09:30 PM Thread Starter
1BAD98's Avatar
Injectors sold this morning. Thanks
1BAD98 is offline
For Sale injectors, maf and fpr, fuel pump eighty8gtfiveo Fuel System & Related 4 11-30-2010 10:34 PM
fuel injectors swap parish99 5.0/5.8 Engine Tech 2 01-04-2002 10:51 PM
fuel injectors swap parish99 GT & SOHC 0 01-04-2002 09:48 PM
