363 liberator longblock? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 08-24-2013, 11:23 AM Thread Starter
what do the compression ratios come out to with the flat top pistons the 14cc dish and the 20cc dish pistons
1985 TwisterII
KC Tony is offline
post #2 of 2 Old 06-11-2014, 10:55 AM
It depends on your the size of the deck height and cylinder bore on the block, stroke of the crankshaft, combustion chambers on your heads, and the compressed thickness of your head gaskets.
My advice is to find an online compression calculator and enter the appropriate values to get accurate estimates.
My build started with a Dart windsor block with 4.125 bore, a crank with a 4-inch stroke, 58cc AFR heads, and FRPP head gaskets. The computed compression ratio was 10.49, but the heads required some minor milling, so I'm expecting something closer to 10.6 or 10.7. I won't know for sure until the motor is done (sometime next week).
jsimmons is offline
For Sale 86 COUPE DART 363 88mm guyny408 Mustangs For Sale/Wanted, 1979-1986 25 09-11-2013 08:25 AM
363 build in process nosbryan 5.0/5.8 Engine Tech 36 09-09-2012 12:46 AM
FORD STROKERS DART 363 dyno..finally raw85 5.0/5.8 Engine Tech 33 06-17-2012 09:46 PM
For Sale iron eagle big bore 363 turbo longblock jnobs Windsor Engine Parts 5 07-01-2011 10:15 PM
For Sale JE Pistons/Rings for 363 Stroker Flat Top Neomustangz Windsor Engine Parts 1 06-26-2011 09:39 PM
