393 stroker questions - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 05-08-2011, 05:31 PM Thread Starter
ive got a 351w motor im about to make a 393 stroker out of. what all am i going to need? ive been told ill need a special oil pan and 351 to 302 swap headers or something? so what all little things like that am i going to need?
1990 fox is offline
post #2 of 8 Old 05-10-2011, 02:55 PM
1971mustang's Avatar
well i am no expert but I am looking into doing a 393 also. From the most part its a 3.85 stroke crank with 351w rods and 302 pistons so would still be using a 351w head.
Now I have seen were people are using other length rods don't know what the advantage/disadvantage would be.
I personally would be interested in knowing what kind of work should be done at the machine shop as far as getting the block ready. What has to be done, what should be done and what can be skipped.
83 351w block .30 over
MSD 6AL, MSD Distributer #8584, Edelbrock PERFORMER RPM 2.02" INTAKE VALVES #60259, Comp cam #35-246-3 519 lift intake, 523 lift exhaust, 28in M/T slicks, Holly 750DP, Subframe connectors, Calvert complete rear pieces, 4.33 9in, hooker header, c4
1971mustang is offline
post #3 of 8 Old 06-21-2011, 05:54 PM
2burnouts's Avatar
Trader Feedback: (22)
no notching required for 393,some use a long rod and some use the short rod,i thought stroke was 3.75 but main thing at machine shop,need to convert it for roller cam.
2burnouts is offline
post #4 of 8 Old 11-22-2011, 09:27 AM
Marbles87fox's Avatar
Trader Feedback: (15)
BEHOLD!
Hahaha. This is an excellent site for great information about stroker engines.
http://www.strokerengine.com/RodStroke.html
Marbles87fox is offline
post #5 of 8 Old 04-17-2012, 12:24 PM
ponylover's Avatar
Honestly having done the 393W, I think you'll be happier with a 408W. And it won't cost you any more than it would to build a 393W of the same caliber of parts. Just my .02
92 Hatch
"You just got to remember that trumpets are made from bicurious fish who spread lies about little people who crashed because they didn't take their five hour energy.. ya dig"
ponylover is offline
post #6 of 8 Old 08-01-2012, 07:31 AM
Mustangmichael's Avatar
Trader Feedback: (59)
A 393 is a 3.85 stroke crank that uses a 5.95 rod and a piston with a 302 pin height. Other rod/piston height combos are out there, but this is the most common it seems. A flat top piston with a 60cc head yields some healthy 12 to 1+ compression ratios depending on valve relief and how high the piston is in the bore.
What you'll need is: 351 headers for a fox(I'm assuming that's what you have), a 351 fox style oil pan(available still from FRPP), a 351 lower intake(they differ from the 302), some sort of retro lifters if you want to run a roller cam and your block is not a 351 roller block, 1/2" head studs or bolts, longer pushrods, extend the hose on your stock fuel rails-front and rear(this is easy to do), and a distributor for a windsor to work with TFI(if you are going EFI). If you are running a hydraulic roller camshaft, then the distributor will need to have a steel distributor gear on it. Hope this helps. I drove a 500 rwhp 393 on the street for about 2 years, and loved every minute of it. It was a stupid fast car.
Michael Bell
email:
92 coupe, coyote 5.0, turbo, manual trans, project in progress....
Mustangmichael is offline
post #7 of 8 Old 09-12-2012, 07:13 PM
If any of you guys want to build a ultra cheap 408, I have a NIB Cast 4'' stroke crank with 3'' mains and 2.10 rod journal. $225 Shipped.
I also have a NIB set of Eagle 4340 H beam 6.2 rods with ARP 2000 rod bolts Id sell with it too.
Unitek is offline
post #8 of 8 Old 01-23-2013, 08:47 PM
still got your budget stroker crank and rods?
if so pm me back please and thanks, or text 7854094640
Dalstrader is offline
393 crankshaft questions USNGT 5.0/5.8 Engine Tech 20 04-22-2011 11:22 PM
For Sale 393 stroker pistons and H-beam rods Whiplash93 Windsor Engine Parts 2 11-22-2010 10:54 AM
Headers for a SN95 393 stroker? 95KBconv 94/95 Tech 2 01-08-2002 02:04 AM
'71 351w stroker questions... RoadRebel 5.0/5.8 Engine Tech 13 12-03-2001 05:09 PM
Which pistons will get me 12.5.1 in a 393 stroker? Green92GT 5.0/5.8 Engine Tech 9 11-30-2001 01:21 PM
