Wide band blanking out. - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 08-03-2019, 12:58 PM Thread Starter
Went to the dyno and pretty much it stopped on top of the run. Signal stopped. It worked again until the top of the run.
Tried grounding the block to the battery grounding the wide band to the block. No luck. Wide band in collector. Any suggestions?
Combo supercharged running on m1. Bs3
Blown and strocked is offline
post #2 of 4 Old 08-04-2019, 10:01 AM
indy2000's Avatar
you have wiring diagram for this mysterious wide band?
indy2000 is offline
post #3 of 4 Old 08-04-2019, 12:36 PM Thread Starter
No diagram. Had it hooked up 2 ways. Had it heated when you first turned on the ignition the second way was you turned it on.
Thinking it is from the vibration harmonics from the supercharger. Going to try to move the sensor closer to the head. 20190802_164744_1564936469754.jpg
post #4 of 4 Old 08-04-2019, 12:45 PM Thread Starter
Sorry for the upside down pic. The sensor plugs straight into big stuff 3 harness.
