Hanging idle - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Unread 05-16-2019, 10:37 PM Thread Starter
Hanging idle
My idle hangs when coming to a stop at a light it will hang at 1500 rpm for like 3 seconds before it begins its decay. I have PRP advantage how do I adjust this so the decay rate drops faster. Makes it difficult to come to a complete
Stop without going hard on brakes
1999 Mustang GT Convertible
4.75 MMR 750se 10.5:1 CR Notched Pistons
Ported PI Heads CMS Turbo 2Cams Eddy Intake 75mm 60lb inj Twin Cobra Pumps Modified FPDM
LOU02STANG is offline
post #2 of 5 Unread 05-16-2019, 10:48 PM
Trader Feedback: (21)
Is there a "dashpot decay"? I'm not familiar with SCT, but others have that under dashpot.....
For everything that is worthwhile, there is a counterfeit.
boostup89 is offline
post #3 of 5 Unread 05-17-2019, 04:58 AM Thread Starter
Ya there is.. Do I raise it or lower it to get the rpm to drop faster?
post #4 of 5 Unread 05-17-2019, 09:09 AM
indy2000's Avatar
does it not have on screen help?
there is also on line courses
indy2000 is offline
post #5 of 5 Unread 05-17-2019, 11:38 AM
If I had to guess, increase decay rate. But not knowing how the software is set up, I don't know.
Crank, No Start Blown88GT MegaSquirt DIYAutotune Systems 34 12-28-2013 12:14 PM
Weird hanging idle issue, not like most 99FiveOh 94/95 Tech 18 12-07-2013 02:47 PM
Hanging idle Mach 1 H8TOLUZ SVT & DOHC 16 09-11-2013 06:16 AM
Problem with hanging idle jaybo9450 94/95 Tech 6 03-15-2007 02:18 PM
Horrible Hanging Idle when hot - also stalls Rel 94/95 Tech 8 08-26-2003 05:48 PM
