Any 302 based COP ignition setups? - Ford Mustang Forums : Corral.net Mustang Forum
 1Likes
  • 1 Post By mr_minnis
post #1 of 16 Old 03-09-2019, 10:28 PM Thread Starter
TxFireman1972's Avatar
Trader Feedback: (87)
Any COP ignition setups on a 8.2 deck with a traditional EFI intake (TFS, Systemax, etc)? I prefer the coils mounted on the valve covers because havenít really seen any remote mounted setups I like. Just not sure if itís possible on a 8.2 deck setup.
Looking for something similar to this, but this is 351 based.
One day the same people that doubt your dream will tell people how they met you!
TxFireman1972 is online now
post #2 of 16 Old 03-12-2019, 11:36 PM Thread Starter
Guess not lol
post #3 of 16 Old 03-13-2019, 02:48 AM
Decipha's Avatar
EFIDynoTuning ? View topic - Fox w/returnless fuel
decipha @ EFIDynoTuning
www.efidynotuning.com
Decipha is offline
post #4 of 16 Old 03-13-2019, 06:35 AM Thread Starter
That really doesn’t have anything to do with what I asked about. Thanks anyway
post #5 of 16 Old 03-13-2019, 07:46 AM
Please call me Mike
mr_minnis's Avatar
Trader Feedback: (46)
The reason most people have box style and carb style intakes when running COP ( although the correct name is coil near plug, coil over plug refers to the spark plugs with coil attached like the modular motors have) is the intake going over the drivers side valve cover. Granted you can run a 1 inch spacer and create the clearance. However the passenger side has its own issues, the throttle linkage and IAC can be problematic. Again with 1 inch spacer, right Throttle body spacer and coil mounting it should work.
I purchased some aluminum coil mounts and had them welded to the covers. I wish I would have spaced them differently because it is painful near linkage to remove IAC connector.
I think the ls2 coils are about 2 inches high.
TxFireman1972 likes this.
84K 88 LX Vert 5spd: 3.73s.
mr_minnis is offline
post #6 of 16 Old 03-13-2019, 04:01 PM
pkstang's Avatar
Trader Feedback: (161)
looks to be a pro-m racing setup... i have the same setup (351W w/efi 5.8 intake)
pk
pkstang is offline
post #7 of 16 Old 03-13-2019, 04:05 PM Thread Starter
I’m not asking about the EFI system. I’m running Holley EFI and have that part covered. I’m asking about coil mounting locations.
post #8 of 16 Old 03-13-2019, 04:09 PM
pkstang's Avatar
in that case
https://forums.corral.net/forums/5-0...coil-plug.html
https://forums.corral.net/forums/sup...nting-diy.html
pkstang is offline
post #9 of 16 Old 05-10-2019, 10:31 AM
I did it but with the stock-style intakes overhanging the valve covers so closely, D585 coils simply do not fit. I used an explorer cam sync and mounted the coils in the space that the distributor used to occupy, right in front of the manifold. It's ugly.
5.0thunder is offline
post #10 of 16 Old 05-10-2019, 10:49 AM Thread Starter
I went ahead and mounted them on the valve covers
post #11 of 16 Old 05-10-2019, 11:06 AM Thread Starter
How did the Explorer cam sync work out? Trying to decide between that or the extra $$$ for the MSD one.
Arenít there a couple different versions of the Explorer one? Which one do I need? Thanks!
post #12 of 16 Old 05-10-2019, 01:06 PM
That looks nice for the driver side. What about passenger side where the throttle body cable is located? I have an explorer intake and even with a 1" spacer there wasn't enough room.
The explorer cam sync is solid, no need for a high dollar dual sync or holley (china) electronics. I use megasquirt and designed/cut a trigger wheel that sandwiches between the balancer and crank pulley, then used a modified stock timing pointer to hold a hall effect sensor. If you use a crank trigger like this, you don't need a dual sync cam setup so the exploder sync works great. The two versions were VR sensor and Hall Effect Sensor. I prefer hall effect because I had issues with noise on VR circuits in the past. This leaves a VR input open on my ECU that I can use for something slightly less critical, like the VSS coming from the trans.
the hall effect explorer cam sync is a 3-pin connector whereas the VR connector is 2-pin. I thin they were used from 1998-2000 5.0 explorers?
post #13 of 16 Old 05-10-2019, 01:21 PM Thread Starter
Pass side mocked up
post #14 of 16 Old 05-10-2019, 04:23 PM
I should get one of those intakes. lol
post #15 of 16 Old 05-10-2019, 05:59 PM Thread Starter
Itís a TFS-R thatís been smoothed and polished. Also has a 1Ē spacer
post #16 of 16 Old 07-22-2019, 11:13 PM
Anyone have updated pics with IGN-1A coils?
COP TZR is offline
For Sale ICE 7 Ignition System for 302 coldblue012 Electronics and Entertainment 2 09-12-2012 01:47 AM
Blown setups: MSD or Crane Ignition? blueline Superchargers 13 02-06-2009 11:47 AM
going from 302 to 351. What parts are interchangable? Mize blown89lx 5.0/5.8 Engine Tech 32 07-18-2007 03:16 PM
4 banger to 5.0 efi, help please Miley_Stang General Mustang Tech 9 08-15-2005 03:17 PM
Help me decide - sportsman 302 or a 351w based block for 600rwhp? JimsYellow88 5.0/5.8 Engine Tech 17 08-21-2002 05:36 AM
