TFI harness female connector - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 08-30-2018, 12:55 PM Thread Starter
Mustang5L5's Avatar
Looking for a FEMALE TFI connector. I need the opposite connector for this that would normally be the TFI module itself.
https://www.diyautotune.com/product/...tfi-ignitions/
I want to run EDIS, but would like to make a plug-and-play harness that i can plug into the current TFI male plug in case i ever need to go back to the distributor setup. I'm not a fan of cutting off OE wiring connectors if i can avoid it. I'm hoping that's a common, standard type connector and i can locate a counterpart on Mouser.
Mike
--1988 Mustang LX 5.0--
Mustang5L5 is offline
post #2 of 3 Old 08-31-2018, 09:01 AM
I was looking for the same when I first converted to a crank trigger so that I could easily swap back and forth and came up short. I ended up gutting a TFI module.
seijirou is offline
post #3 of 3 Old 08-31-2018, 09:16 AM Thread Starter
Mustang5L5's Avatar
That's what i was thinking of doing as well if i can't find the proper connector. I've got a perfect donor TFI
Mike
Exercising demons.... Sledger46 5.0/5.8 Engine Tech 7 04-16-2017 09:52 PM
1995 cobra wiring harness locations and connector questions with pictures mustang2pt3 94/95 Tech 8 03-29-2014 02:35 PM
Need pinout for single Brown connector 93 mustang 5.0 ECU harness 88blk5.0 General Mustang Tech 3 07-20-2013 05:51 PM
87 MAF conversion no good without 89 harness? 1983Ttop5.0 Engine Management Systems 0 09-16-2012 01:39 AM
Want To Buy anybody have a junk fox engine harness? need TPS connector MIKE92NOTCH Electronics and Entertainment 5 03-17-2012 02:27 PM
